Subsonic settings not being saved [Resolved]
Postby millhouselives » Thu Feb 09, 2012 3:33 pm
Problem Description: when I go to "players" and select the player
name I created to use with the roku and then press the save tab....it
does not save the change I just made.
Troubleshooting Steps: I haven't tried anything because I don't know where to start.
Playback Application and version: Standard Subsonic Web Interface
Subsonic Version: 4.6 (build 2583) – December 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_30, Windows 7 (31.9 MB / 96.7 MB)
Hardware Platform: Windows 7 Pro
Java Memory Limit: I am not sure how to check this?
Thank you for any help...
millhouselives
Re: Subsonic settings not being saved
Postby BKKKPewsey » Thu Feb 09, 2012 5:21 pm
millhouselives wrote:Hardware Platform: Windows 7 Pro
Control Panel/settings tab
Postby millhouselives » Thu Feb 09, 2012 6:18 pm
Thank you
Java Version is Version 6, update 30 (build 1.6.0_30 b12)
millhouselives
Postby BKKKPewsey » Fri Feb 10, 2012 3:16 am
BKKKPewsey wrote:Control Panel/settings tab
That was the Subsonic control panel :?
Postby millhouselives » Fri Feb 17, 2012 7:56 pm
thank you, with your help I figured this out.
millhouselives
Users browsing this forum: No registered users and 60 guests
