"folder.jpg" for album art rather than "cover.jpg"?
Postby Boutros » Thu Feb 09, 2012 6:17 pm
So, I've got a pretty extensive archive of music, and have obsessively curated it to make sure that I have good album art for each album folder. However, having started this process in a Windows-centric world, I've always used "folder" as the filename.
I just discovered yesterday that Subsonic defaults to look for "cover" as the filename. Is there a setting somewhere where I could tell it to look for "folder" instead? Or does this even matter (i.e. if no "cover" is found, it'll just use the next image file it finds, in this case "folder")?
Boutros
Re: "folder.jpg" for album art rather than "cover.jpg"?
Postby bushman4 » Thu Feb 09, 2012 6:21 pm
Settings->General->Cover art files
Cover art files
Allows you to specify the type of files that should be recognized as cover art when browsing through the media folder.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Boutros » Thu Feb 09, 2012 6:24 pm
Well, that... should have been obvious, I guess. :oops:
Thanks for the pointer, Glenn!
Boutros
