Android connect problem.
Postby mouwendijk » Thu Feb 09, 2012 9:34 pm
i installed subsonic on my android phone. When my phone is connected by wifi al works fine. :D
But when wifi is of and my phone connects trough a mobile connection (3g or hspa) then i get a network error. :( Internet is working fine for the rest of my phone.
The Subsonic server is installed on a Debian 5 VPS server i own and the web interface is reacheble and working great. And the webinterface is also reacheble from my phone.
In my settings i have tried the following servers:
http://mydomain.nl:4040 (replaced with domain of server)
http://12.12.12.12:4040 (replaced with ip adres of server)
when setting easy-to-remember setting i get following: Status: mydomain.subsonic.org responded successfully.
Help needed here. :roll:
thanks.
mouwendijk
Re: Android connect problem.
Postby bushman4 » Fri Feb 10, 2012 2:04 pm
Have you tried a server address of mydomain.subsonic.org (all lowercase)?
I found out that capitalization in the subsonic address causes connection failures...
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby GJ51 » Wed Aug 01, 2012 7:41 am
The hard ones.
Postby twistedviewlabs » Thu Oct 25, 2012 12:45 am
i've been having an issue attempting to connect to my server via my android device. i had the HTC Evo3D which worked swimmingly until about 2 weeks ago and thought maybe it was the device. nope, i tried on my replacement Samsung Galaxy S Epic 4G...same issue. all the info is correct as far as login info. ports are forwarded correctly on my router.
i'm having this issue regardless of being connected to my wifi or 3G/4G connection.
anyone have a fix or workaround for this?
btw...here's my collection stats. i've seen a few posts that mention splitting up the files into smaller folders but, again, i never had an issue until 2 weeks ago...
1,423 artists
9,101 albums
113,217 songs
874.78 GB
8,170 hours
twistedviewlabs
Postby alphawave7 » Thu Oct 25, 2012 1:47 am
twistedviewlabs wrote:i've been having an issue attempting to connect to my server via my android device. i had the HTC Evo3D which worked swimmingly until about 2 weeks ago and thought maybe it was the device. nope, i tried on my replacement Samsung Galaxy S Epic 4G...same issue. all the info is correct as far as login info. ports are forwarded correctly on my router.
1,423 artists
9,101 albums
113,217 songs
874.78 GB
8,170 hours
Try canyouseeme.org for your chosen port # to esnsure your router is still configured to use it.
Users browsing this forum: Bing [Bot] and 21 guests
