Backing Subsonic Up
Backing Subsonic Up
Postby text » Sun Feb 12, 2012 3:32 am
How do I back up the complete subsonic settings? I'm going to uninstall, delete every change it made to my computer and reinstall it. But I don't want to sift through all the settings again. I just want to install it and it will be like I never uninstalled it.
User settings, podcasts settings, port settings, every little thing.
Thanks for any help,
Text
Windows Vista 64
text
Re: Backing Subsonic Up
Postby bushman4 » Sun Feb 12, 2012 3:21 pm
take a copy of the c:\subsonic directory. All user settings are there. The only settings that you would miss at that point are the basic subsonic settings set through the subsonic control panel on the system tray... ports, context path, and memory.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby text » Sun Feb 12, 2012 9:50 pm
Thanks, Glenn.
text
Postby text » Tue Feb 14, 2012 6:46 am
Well, that didn't work. I did exactly as you said. Now all of my settings are lost. All users are lost. I still have the folder from the original c:\subsonic
But everything is reset. How do I put it back?
text
Postby daniell » Tue Feb 14, 2012 7:11 am
In Linux..
* Stop Subsonic.
* copy back the file, subsonic.script to /var/db folder
* Copy back the file, subsonic.properties to var/subsonic folder
* Start subsonic..
* option.. Copy back folder thumbs to /var/thumbs
* run search indexing.
You should be up and running with all your settings and users.
Supermicro Intel(R) Core(TM) i7-3555LE CPU @ 2.50GHz, 4 cores 8gb ram
CentOS Linux 6.6 Server, jetty-6.1.x, java 1.7.0_71, Linux (143,2 MB / 437,5 MB) Subsonic 5.1
Supermicro Intel® Atom™ D510 4gb ram
Sophos Security Gateway UTM /v9
daniell
Postby text » Tue Feb 14, 2012 7:16 am
I am on Windows vista.
And I copied the entire folder like he said. Everything else has been deleted. None of the settings are there. I would like to know if it is possible to fix the situation I am in.
text
Postby daniell » Tue Feb 14, 2012 7:31 am
Well, you could try to stop the subsonic before you start to copy
back the files "subsonic.script" and "subsonic.properties"
I would guess this should be the same in Windows/Linux.
daniell
Postby text » Tue Feb 14, 2012 7:38 am
Of course I did that when I installed. I stopped the service and copied the folder over. No settings were copied. Now, nothing is working. Even my android app will not connect to the server, even though all the IP and router settings are the same, and they're same in the Subsonic control panel.
text
Postby daniell » Tue Feb 14, 2012 7:47 am
IC.
I suggest you uninstall and remove all subsonic folders, then reinstall it.
Then you stop the subsonic service and copy and overwrite ONLY the 2 files mention earlier her.
daniell
Postby text » Tue Feb 14, 2012 7:52 am
daniell wrote:IC.
I suggest you remove/uninstall the subsonic, and reinstall it.
That did it. Now everything is working again. I appreciate it a lot. For a minute there I was about to rage.
text
Postby daniell » Tue Feb 14, 2012 7:55 am
Glad i could help :D
daniell
