FLAC Transcoding no output to player
Postby Joeshmoe » Sun Feb 12, 2012 6:53 pm
Ok, been banging my head on the wall with this for days now and I have no idea how to proceed.
I am trying to get FLAC transcoding to work and initially the problem seemed to be related to ffmpeg but now I'm pretty sure it's not.
Here is my Info:
Ubuntu 11.10
running a manual install of 4.6
SUBSONIC_HOME=/var/subsonic
SUBSONIC_HOST=0.0.0.0
SUBSONIC_PORT=4040
SUBSONIC_HTTPS_PORT=0
SUBSONIC_CONTEXT_PATH=/
SUBSONIC_MAX_MEMORY=1024
SUBSONIC_PIDFILE=
SUBSONIC_DEFAULT_MUSIC_FOLDER=/var/music
SUBSONIC_DEFAULT_PODCAST_FOLDER=/var/music/Podcast
SUBSONIC_DEFAULT_PLAYLIST_FOLDER=/var/playlists
/var/subsonic/transcoding looks like this:
lrwxrwxrwx 1 root root   21 2012-02-11 11:31 ffmpeg -> /usr/local/bin/ffmpeg*
lrwxrwxrwx 1 root root   13 2012-01-18 08:48 flac -> /usr/bin/flac*
lrwxrwxrwx 1 root root   13 2012-01-18 08:48 lame -> /usr/bin/lame*
Log file looks like this:
[2/12/12 11:29:30 AM MST]   INFO   PlaylistInputStream   chris listening to "The Immaculate Collection [1990]/12 Madonna - The Immaculate Collection [1990]- Like A Prayer.flac"
[2/12/12 11:29:30 AM MST]   DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/home/music/Madonna/The Immaculate Collection [1990]/12 Madonna - The Immaculate Collection [1990]- Like A Prayer.flac] [-ab] [320k] [-v] [0] [-f] [mp3] [-]
And this is all that shows up until the next time I try to play anything
So as you can see by the log info subsonic is trying to transcode the file into STDOUT but the player comes up with nothing, it loads the time of the song but never plays.
If I run the command:
./ffmpeg -i /home/music/Madonna/The\ Immaculate\ Collection\ \[1990\]/12\ Madonna\ -\ The\ Immaculate\ Collection\ \[1990\]-\ Like\ A\ Prayer.flac -ab 320k -v 0 -f mp3 test.mp3
replacing the "-" at the end with "test.mp3" file name I get a playable MP3.
So this tells me that subsonic is not getting the STDOUT from the streamer but I have no idea what else to do?
Any ideas?
Just in case here is the ffmpeg info as well:
ffmpeg version git-2012-02-11-fd0b8d5 Copyright (c) 2000-2012 the FFmpeg developers
  built on Feb 11 2012 11:25:21 with gcc 4.6.1
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab
  libavutil      51. 39.100 / 51. 39.100
  libavcodec     54.  1.100 / 54.  1.100
  libavformat    54.  0.100 / 54.  0.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 62.100 /  2. 62.100
  libswscale      2.  1.100 /  2.  1.100
  libswresample   0.  6.100 /  0.  6.100
  libpostproc    52.  0.100 / 52.  0.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Joeshmoe
Re: FLAC Transcoding no output to player
Postby BKKKPewsey » Sun Feb 12, 2012 7:17 pm
Your transcoding settings look ok to me so its a bit of a mystery?
Have you tried deleting the player and letting SS create a new one?
I am assuming that it is only flac files you are having problems with?
Postby Joeshmoe » Sun Feb 12, 2012 7:19 pm
Yep, tried that a few times too
Joeshmoe
