External Players
External Players
Postby Alexdavall » Mon Feb 13, 2012 1:24 am
How do I connect with a source say, Virtual DJ Pro 7? Since it is the only DJ software I have and the only one I know how to use...
Alexdavall
Re: External Players
Postby GJ51 » Mon Feb 13, 2012 6:02 am
It's hard to answer your question without a better understanding of what you are trying to acomplish. Are you trying to access your music library remotely through Subsonic and play it through VDJ? If so, the you need to make VDJ your default music player on the PC your using to access SS and experiment with using an "External Player with Playlist".
I think it may just be easier to learn the SS interface than trying to pipe it to VDJ.
Postby ytechie » Mon Feb 13, 2012 7:03 pm
It's probably not the easiest thing to get subsonic flowing through VDJ for actual live mixing. You might be able to get a stream set up, but for DJing I don't think that's going to cut it.
ytechie
Postby jonnymnemo » Thu Oct 25, 2012 9:56 am
Any news for that topic ?
To be able to use a software like virtual dj (or another one :wink: ) would be awesome !
Maybe a plugin in an existing software like subwiji...
jonnymnemo
Postby pir8radio » Sat Oct 27, 2012 4:19 am
thats not what subsonic does best... run vdj on your home lan, map the network drive build your vdj database, then setup a VPN and then vpn into your home lan and connect to the same mapped drive... VDJ does load up the mp3 your about to mix with so you wont have any skipping, but you have to wait for it to load up before you can mix it.
pir8radio
Users browsing this forum: Bing [Bot] and 22 guests
