how do i set up lyrics feature?
Postby intangir » Mon Feb 13, 2012 3:54 am
i installed it everything seems to work fine, even podcasts
but the lyrics search never returns any results. is there some special setup i need?
i have the mp3s tagged well, it shows the artist and song accurately, but never comes up with anything
does it save them locally before displaying in some local path that i need write permission setup on? cause i did do a bit of weirdness with the path settings so that i can run subsonic on a share, i had to setup podcasts directory special. do i need to do that for a lyrics directory? if so, what path. if not what else do i need to do?
intangir
Re: how do i set up lyrics feature?
Postby GJ51 » Mon Feb 13, 2012 5:26 am
The interface needs to be updated.
http://www.chartlyrics.com/api.aspx
The request to update has already been submitted to the developer.
Postby Olaf » Fri Mar 16, 2012 9:12 am
i have recently installed subsonic and i am highly interested in this feature. Since this post is not too old, i would like to know about the implementation status.
Will this be implemented by any chance or is there another way to get to some lyrics?
Cheers
Olaf
Olaf
Postby BKKKPewsey » Fri Mar 16, 2012 1:24 pm
From Sindre's TODO List
DONE IN 4.7
Improvements to lyrics search
Postby DancingOmelette » Tue Jun 26, 2012 10:44 am
I'm using 4.7 beta 2 and the lyric search is still useless... It wasn't finding anything, so I decided to try a famous pop song - "Like a Virgin" by Madonna. It didn't find the song when I typed "Like a virgin", but it did find it when I typed "Like a Virgin". Really? The search is so fussy it's even case sensitive? So any tiny little thing different in the song title means it's not going to match? That's not going to be very useful.
DancingOmelette
