Creating search index: Not found on disk
Postby pemholder » Tue Feb 14, 2012 3:38 pm
after rebulding the search index I find some entries in the log-file:
DEBUG   SearchService   Logically deleting info for album .......Not found on disk
The folders and files are on the disk, subsonic shows them and I can see no reason why the SearchService is not able to find them.
There are only a few folders that can't be found, 99,999 % are found.
Any hints?
pemholder
Re: Creating search index: Not found on disk
Postby BKKKPewsey » Tue Feb 14, 2012 4:52 pm
If you do a search for that album does it appear in the search results?
I have seen this in my log also for files that (as far as I know) haven't been renamed in anyway but they still appear in search results :?
Postby ytechie » Wed Feb 15, 2012 9:35 am
I tried to figure this out for quite some time. I got nowhere. I tried updating the dates modified, created and accessed to no avail. I couldn't determine a solid reason for the odd behavior.
ytechie
Postby pemholder » Wed Feb 15, 2012 11:32 am
BKKKPewsey wrote:If you do a search for that album does it appear in the search results?
Yes, They do.
Renewing the index today did not bring these logs again.
pemholder
