How to add VIDEO files?
Postby mudsharkymon » Sat Feb 18, 2012 1:00 am
I upgraded to 4.6 and under SETTINGS > Media Folders I added the path to the videos I have. SubSonic rebuilt indexes but I do not see a way to access videos.
Any ideas?
Android Subsonic Version: 2018 10 06
Hardware Platform: TrueNAS
mudsharkymon
Re: How to add VIDEO files?
Postby Beowolf » Sat Feb 18, 2012 5:19 am
from what i understood streaming the video is a 30 trail setting up if you have not registered *donated u wont see them
i have added the videos the same as i loaded the music.
1,959 artists
1,970 albums
13,978 songs
941.65 GB (~ 14,628 hours)
Beowolf
Postby mudsharkymon » Sat Feb 18, 2012 4:38 pm
I donated quite sometime ago so after u/g I should see the full video-capable system w/o having to re-donate I assume.
Attached is a screen-shot showing how the paths are setup. Music works, Video doesn't.
If I understand what you're saying, I should expect to see videos mix in with the albums? That seems an odd way to display content, mixed together like that!
Either way all the albums show perfectly well but no videos are to be found.
For example, in this excerpt from the left column (albums) I'd expect to see "A Clockwork Orange" but it's not there. (Neither is it listed under "A".)
Les Claypool
Clutch
Coverdale-Page
I *did* have a problem a few years back with SubSonic where I tried an upgrade, didn't like it and rolled back to the 3.x version and in the process had some skin problems. Maybe that's what's going on here!
mudsharkymon
Postby BKKKPewsey » Sat Feb 18, 2012 5:24 pm
Subsonic is for some reason not seeing your video folder.
When you have more than 1 folder in settings/Media Folders you should see a drop down box in the left frame above
"Shortcuts" with your folders listed.
These also makes it easy to separate your Simpsons from your Steely Dan :)
Try temporarily adding another music folder and see if you can make SS refresh.
Also try stopping and restarting SS.
Postby mudsharkymon » Sat Feb 18, 2012 7:18 pm
Adding another folder (Music2) as a test and refreshing the browser window worked. (I bet I had only to refresh the browser!)
Thanks folks!
mudsharkymon
