Video transcoding quality/ratio messed up since version 4.6?
Postby SparkyRih » Tue Feb 21, 2012 1:12 pm
I'm on Ubuntu 11.10, and I've upgraded from version 4.4 to 4.6...
But now a lot of my video's, which played fine before, are now playing in low quality (video and audio), and some also use the wrong ratio (4:3 instead of 16:9)...
I haven't changed any transcoding settings...
Could some-one please help me?
Edit: My CPU load is also not normal anymore, even after a reboot, if I play a couple videós, and after that no-one is playing any video's... the server keeps using all its CPU resources.... I hope this issue can be fixed soon? :S
VMWare ESXi 5.5 > Ubuntu 16.04 > Subsonic 6.0 (Modded with PHP based registration feature)
SparkyRih
Re: Video transcoding quality/ratio messed up since version
Postby BKKKPewsey » Tue Feb 21, 2012 3:26 pm
I cannot help because I do not use your OS :(
But if you post your SS log output while a "dodgy" video is playing it might help others to see the problem.
Can you determine what task/service is "hogging" your cpu resources?
Postby SparkyRih » Tue Feb 21, 2012 3:59 pm
Here i's my log... the last video is one of the vids that played perfectly on ver4.4, but is in low quality and wrong ratio now...
The CPU issue might be something different... let's see if we can fix the main issue first...
Log:
[2/21/12 4:52:57 PM CET]
INFO
PlaylistInputStream
Marc listening to "Examen Jennifer/Jennifer van Riet 1e Dan Compilatie.mp4"
DEBUG
TranscodeInputStream
Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/mnt/disk2/judo/Examen Jennifer/Jennifer van Riet 1e Dan Compilatie.mp4] [-async] [1] [-b] [1000k] [-s] [540x360] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
DEBUG
InputStreamReaderThread
(/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
DEBUG
(/var/subsonic/transcode/ffmpeg) built on Aug 9 2011 14:18:27 with gcc 4.5.2
DEBUG
(/var/subsonic/transcode/ffmpeg) configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
DEBUG
(/var/subsonic/transcode/ffmpeg) libavutil 51. 11. 1 / 51. 11. 1
DEBUG
(/var/subsonic/transcode/ffmpeg) libavcodec 53. 9. 1 / 53. 9. 1
DEBUG
(/var/subsonic/transcode/ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
DEBUG
(/var/subsonic/transcode/ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
DEBUG
(/var/subsonic/transcode/ffmpeg) libavfilter 2. 28. 1 / 2. 28. 1
DEBUG
(/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
DEBUG
(/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
DEBUG
DEBUG
(/var/subsonic/transcode/ffmpeg) Seems stream 1 codec frame rate differs from container frame rate: 59.94 (60000/1001) -> 59.94 (60000/1001)
DEBUG
(/var/subsonic/transcode/ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/mnt/disk2/judo/Examen Jennifer/Jennifer van Riet 1e Dan Compilatie.mp4':
DEBUG
(/var/subsonic/transcode/ffmpeg) Metadata:
DEBUG
(/var/subsonic/transcode/ffmpeg) major_brand : MSNV
DEBUG
(/var/subsonic/transcode/ffmpeg) minor_version : 19529811
DEBUG
(/var/subsonic/transcode/ffmpeg) compatible_brands: MSNVmp42isom
DEBUG
(/var/subsonic/transcode/ffmpeg) creation_time : 2011-12-13 23:06:39
DEBUG
(/var/subsonic/transcode/ffmpeg) Duration: 00:04:37.81, start: 0.000000, bitrate: 3135 kb/s
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.0(eng): Audio: aac, 48000 Hz, stereo, s16, 128 kb/s
DEBUG
DEBUG
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.1(eng): Video: h264 (Main), yuv420p, 720x480 [SAR 40:33 DAR 20:11], 3003 kb/s, 59.94 fps, 59.94 tbr, 60k tbn, 59.94 tbc
DEBUG
DEBUG
DEBUG
(/var/subsonic/transcode/ffmpeg) [buffer @ 0xa6262e0] w:720 h:480 pixfmt:yuv420p tb:1/1000000 sar:40/33 sws_param:
DEBUG
(/var/subsonic/transcode/ffmpeg) [scale @ 0xa61cd60] w:720 h:480 fmt:yuv420p -> w:540 h:360 fmt:yuv420p flags:0x4
DEBUG
(/var/subsonic/transcode/ffmpeg) [libx264 @ 0xa63c940] using SAR=40/33
DEBUG
(/var/subsonic/transcode/ffmpeg) [libx264 @ 0xa63c940] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle Cache64
DEBUG
(/var/subsonic/transcode/ffmpeg) [libx264 @ 0xa63c940] profile High, level 3.1
DEBUG
(/var/subsonic/transcode/ffmpeg) [libx264 @ 0xa63c940] 264 - core 116 r2044 392e762 - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=3 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc=abr mbtree=0 bitrate=1000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00
DEBUG
(/var/subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
DEBUG
DEBUG
DEBUG
DEBUG
DEBUG
DEBUG
(/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.0(eng): Video: libx264, yuv420p, 540x360 [SAR 40:33 DAR 20:11], q=2-31, 1000 kb/s, 1k tbn, 59.94 tbc
DEBUG
DEBUG
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: libmp3lame, 44100 Hz, 2 channels, s16, 64 kb/s
DEBUG
DEBUG
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream mapping:
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.1 -> #0.0
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.1
DEBUG
(/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
SparkyRih
Postby GJ51 » Thu Feb 23, 2012 2:29 am
I've been doing a lot of testing recently and have a few conclusions that might help you out.
Video seems to run best when you download the latest build of ffmpeg for your OS and replace the ffmpeg.exe in the transcode subdirectory. The newer releases of ffmpeg seem to do a much better job of utilizing multi-core CPU's.
Audio, on the other hand is a different story if you use mp3 >ogg for mobile. I haven't been able to get that working properly since version 4.4. Taking the ffmpeg.exe from the 4.4 build and dropping it into one of my SS sites running ver. 4.5 enabled me to do the mp3 > ogg thing again.
But if you are only concerned with improving video performance and don't need to transcode to ogg, then go to the ffmpeg site and grab the latest version for your OS and do the update.
Postby SparkyRih » Thu Feb 23, 2012 12:31 pm
All my ubuntu packages are up-to-date, so that inocludes ffmpeg...
SparkyRih
Postby SparkyRih » Tue Feb 28, 2012 7:08 pm
Anyone any other suggestions?
SparkyRih
Postby SparkyRih » Mon Mar 12, 2012 5:31 pm
No-one?
SparkyRih
Postby GJ51 » Mon Mar 12, 2012 7:11 pm
Postby SparkyRih » Wed Mar 14, 2012 12:49 pm
My ffmpeg is up-to-date...
SparkyRih
Postby GJ51 » Wed Mar 14, 2012 5:01 pm
Then try rolling back the ffmpeg version to either the original SS distribution or the version that came with the SS version that worked previously.
Different versions of ffmpeg have very different capabilities.
