subsonic.sh location on QNAP WAR deployment
Postby redranger » Wed Feb 22, 2012 8:37 pm
Hi....
Does anyone know where the subsonic.sh file is located on a QNAP WAR deployment?
Thank you!
Thank you for your help.
Regards!
/Redranger
redranger
Re: subsonic.sh location on QNAP WAR deployment
Postby redranger » Mon Nov 04, 2013 11:05 pm
Was this just a stupid question or? Seems that there is no subsonic.sh on the Qnap WAR deployment. Can someone confirm that is correct?
Thank you.
Regards!
/Redranger
redranger
Postby Jebba » Thu Nov 07, 2013 2:14 pm
My subsonic.sh is located at /share/MD0_DATA/.qpkg/Subsonic. This is the same location for the .war file.
It is installed from the 'official' Qnap package on a 419p+ with RAID1 for what it's worth.
Hope it helps!
Jebba
Postby redranger » Sat Nov 09, 2013 7:36 pm
Hi Jebba,
Thank you very much for answering.
I do not have a Subsonic dir there. I have one under /share/MD0_DATA/.qpkg/Tomcat/tomcat/webapps and because running on a QNAP I changed the location of the Subsonic db and settings away from the var dir, as this dir is located in the volatile area (which gets erased on each reboot of the QNAP). That dir is: /share/MD0_DATA/Subsonic - and no .sh file there either.
Any other ideas?
Regards!
/Redranger
redranger
Postby Jebba » Wed Nov 13, 2013 12:30 pm
This might be a bit brute force, but you could try to find subsonic.sh by doing a file find with WinSCP in /share/
Alt-F7 --> file mask: subsonic.sh & search in: /share/
It found my subsonic.sh without a problem :)
Btw: My 419p+ is an ARM model, so I do not use Tomcat to run Subsonic. ARM only support JRE as far as I know.
Good luck!
Jebba
Users browsing this forum: Google [Bot] and 17 guests
