While browsing in Subsonic, page will refresh to Random
Postby dhilberg » Sun Feb 26, 2012 6:28 pm
First off, I apologize if this has been asked elsewhere. I have searched and didn't find anything similar.
While browsing albums in the Subsonic Web client, occasionally the page will refresh and I will be directed back to the Random album (home) screen. This can be incredibly frustrating, especially--for example--when you are in the middle of creating a playlist and have to re-navigate back to where you were and re-select the songs you had chosen.
Is there a way to disable this "feature"?
I have looked and been unable to find a setting related to this, unless I am completely missing it.
Thanks in advance for any assistance.
dhilberg
Re: While browsing in Subsonic, page will refresh to Random
Postby BKKKPewsey » Sun Feb 26, 2012 7:13 pm
Postby dhilberg » Sun Feb 26, 2012 7:29 pm
Excellent, thanks so much!
I need to work on my search-fu apparently.
dhilberg
Postby bushman4 » Mon Feb 27, 2012 3:52 pm
The other option is to leave it as is, and when it happens to switch on you when you don't want it to, right click in that pane and choose "back."
I frequently use this feature when updating tags and art for "recently added" albums... I click on the recently added link, select the first album with no art, click the "Change Art" link and select the art. Then, instead of using the "back" links on the Choose Album Art page, I right click and choose back, and then right click and choose back again, and I am back at the "recently Added" list in the same location I was before.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby dhilberg » Tue Feb 28, 2012 6:49 pm
Thanks for the suggestion. But I ended up just commenting out that line in the main.jsp file as suggested in the link above. I also commented out the similar refresh line in home.jsp to prevent the automatic reloading of the random page. I can click the "more" link if I want to refresh it manually. It's much better now. :)
BTW, awesome library! Wow. :shock:
dhilberg
Users browsing this forum: No registered users and 41 guests
