Subsonic not showing up
Postby fiercealmond » Tue Sep 25, 2007 2:36 pm
Subsonic comes up fine when I run it from localhost:80/subsonic, but when I try (My IP):80/subsonic, all that comes up is a blank white page with a text form.
Any suggestions?
fiercealmond
Postby FlyingSaucrDude » Tue Sep 25, 2007 3:42 pm
Could you post more about your configuration (OS, Tomcat version, etc.)?
My gut says this is a firewall issue -- more info about that would be useful too.
FlyingSaucrDude
Postby matthew » Wed Sep 26, 2007 2:35 am
Some ISPs block port 80 if you are a home user, of course this is if you are trying to access your pc from another location, external to your LAN.
I would try to use a different port for tomcat, like port 5000. If this works then you know it is an ISP issue. If it doesnt then like FlyingSaucrDude said it is probably a firewall issue.
So change tomcat to use a different port other than 80:
1. Open C:\Program Files\Apache Software Foundation\Tomcat 6.0\conf\server.xml
2. Find <Connector port="80" protocol="HTTP/1.1" connectionTimeout="20000" redirectPort="8443" />
3. Change port="80" to port="5000"
4. Restart Tomcat.
Matthew.
matthew
Users browsing this forum: No registered users and 70 guests
