Bit perfect playback in Jukebox mode. Is it possible?
Postby Lou Cipher » Thu Mar 01, 2012 1:05 pm
Trying to achieve bit perfect playback using Subsonic. So far I have failed. My soundcard is capable of bit perfect playback and I have accomplished this using mpd. I have verified this by playing flac files encoded in 24/96kHz and the amplifier identifies the stream as 24/96kHz.
Can this be done with Subsonic?
I've specified my soundcard in /usr/bin/subsonic by adding the following line and restarted Subsonic.
'-Djavax.sound.sampled.SourceDataLine=#Port DS [hw:0]' \
watching the stream that actually is sent by 'sudo cat /proc/asound/card0/pcm0p/sub0/hw_param' shows that the stream is still resampled to 44.1kHz.
Anyone got an idea on how to accomplish this?
Lou Cipher
Re: Bit perfect playback. Is it possible?
Postby Lou Cipher » Thu Mar 01, 2012 8:34 pm
Anyone?
Lou Cipher
Re: Bit perfect playback in Jukebox mode. Is it possible?
Postby Lou Cipher » Sun Mar 04, 2012 6:28 pm
Turned out I wasn't selecting my sound card properly. Now it is working as it should. Although it seems like ffmpeg can't handle 24bit audio files.
Lou Cipher
Postby guisar » Wed Apr 04, 2012 1:03 am
How did you modify and did you just eliminate transcoding? Am have the same issue.
guisar
