Streams on mobile but not from work
Postby gregoe86 » Fri Mar 02, 2012 12:29 pm
I've loved using Subsonic for some time, and I have a peculiar issue with streaming from my desktop at work. I know my ports and everything are set from home, since I can access my library from my Android, but it constantly times out from the browser. I know basically nothing about the specs of my work computer, since everything's pretty well locked down, but it's running XP and I have Chrome installed. If I remember it right, Chrome gives me a tcp_timeout message.
Any thoughts? Any way I can access my tunes? Thanks!
gregoe86
Re: Streams on mobile but not from work
Postby BKKKPewsey » Fri Mar 02, 2012 7:15 pm
Is your work computer running behind a corporate firewall?
Try setting up ssl on subsonic and see if that works - it might slip through the firewall :roll:
Postby gregoe86 » Tue Mar 06, 2012 7:52 pm
I'll give that a shot, thanks. Can you point me to a tutorial for SSL on Mac? I'm running OSX Lion on my server.
gregoe86
Postby BKKKPewsey » Tue Mar 06, 2012 11:24 pm
No I cannot but I know a MOD who may be able to help out ....... roll drums :D
Postby colin » Wed Mar 07, 2012 12:04 pm
Try this post:
http://forum.subsonic.org/forum/viewtopic.php?f=6&t=7214
Change:
SUBSONIC_HTTPS_PORT=0
to
SUBSONIC_HTTPS_PORT=443
You need to do this everywhere HTTPS_PORT is referenced.
colin
