Error when trying to create custom domain
Postby stephenconnolly » Mon Mar 05, 2012 9:37 pm
I'm just in the process of setting up subsonic on my home server ( Ubuntu 11.04 ). I have the port forwarding setup correctly, but when I try to setup the custom domain:
stephenconnolly.subsonic.org
I get the following error:
'Status: Failed to test web address. subsonic.org (UnknownHostException).'
Any help appreciated.
Regards,
Stephen
stephenconnolly
Re: Error when trying to create custom domain
Postby paulodell » Mon Mar 05, 2012 10:49 pm
Have you donated and restarted Subsonic?
Cheers
Paul
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Postby stephenconnolly » Tue Mar 06, 2012 9:28 am
No, I thought it was available for use for a certain amount of time and then I had to donate ?
There's a message highlighted in red stating its available until 21st March and after that a donation is required.
I have no problem donating, I just want to try and get it working first.
Regards,
Stephen
stephenconnolly
Postby BKKKPewsey » Tue Mar 06, 2012 1:09 pm
stephenconnolly wrote:No, I thought it was available for use for a certain amount of time and then I had to donate ?
Yes you are correct - you have 30 days trial with all the options available.
I would suggest that you check that the port you have selected is actually open using http://canyouseeme.org
Also make sure that the port is not being used by another app on the server.
Postby stephenconnolly » Wed Mar 21, 2012 8:07 pm
Sorry for the delay in getting back.
I've checked to see if the port if open using the website specified, but the connection just times out.
My router is a Cisco EPC2425, Modem Serial Number 224326128.
I've checked the router settings and as far as I can tell it seems to be setup correctly.
Not sure where to go from here ?
Anyone any thoughts ?
stephenconnolly
Postby BKKKPewsey » Wed Mar 21, 2012 8:58 pm
Try looking on http://portforward.com for your modem to make sure you have set up your router correctly.
SS will not work until your port is open as seen by by http://canyouseeme.org
