Changes
Changes
Postby skully58 » Wed Mar 07, 2012 3:38 pm
I made some changes that I found in the MOD section, 1 was to add a youtube Icon on top and the other was to change the path to the incoming folder. Both times I have saved the original file just in case I made a mistake. So I shut down SS and save the file then made the changes, I didn't care the these options so I copied the original file back but the changes did not revert, I still have the youtube icon that works and the path change as well which never worked, any idea why this is happening?
skully58
Re: Changes
Postby BKKKPewsey » Wed Mar 07, 2012 4:33 pm
Delete your jetty cache and your browser cache and try again.
These cache's can be VERY persistent :roll:
Re: Changes
Postby skully58 » Wed Mar 07, 2012 4:47 pm
Thanks, that was it!
skully58
