[Solved]HELP NEEDED! No JVM found..?
Postby HighCast » Sat Mar 10, 2012 2:43 pm
Since my wife upgraded our "second computer" which used to run Subsonic service, to Java 7 Update 3, the system gives our the following error every time the user logs in to the account.
Also, the Subsonic refuses to start up, even if tried manually from Services.msc.
The same thing happened at one of my friend, which also had upgraded the Java.
downgrading to Java 6 update 30(+) does not help.
How to make the system work again?
The machines are running on Windows 7, with 32-bit OS
Subsonic version is the latest stable.
HighCast
Re: [Solved]HELP NEEDED! No JVM found..?
Postby HighCast » Sat Mar 10, 2012 3:54 pm
Restarting the Windows 7 several times after downgrading to 1.6 Update 31,
I was able to start the Subsonic service again.
HighCast
Postby BKKKPewsey » Sat Mar 10, 2012 5:29 pm
With regard to above:-
From Sindre's TODO List for SS 4.7
Make it work with 64-bit Java 7. Problem with exe4j?
So hopefully next version you can install java 1.7
