Timing out when using remotely [Resolved]
Postby weexpectedthis » Mon Mar 12, 2012 3:19 pm
I am using the "Automatically configure your router" feature inside settings in addition to the fact that I manually set up the port 80 forwarding on the Airport Extreme Router correctly. The status in the Network settings says "Status: Successfully forwarding port 80."
I can hit "http://localhost" just fine, but when accessing it remotely it just times out. Yes I am inputting the correct IP address using "http://whatismyipaddress.com"
Does anyone have any idea?
weexpectedthis
Re: Timing out when using remotely
Postby BKKKPewsey » Mon Mar 12, 2012 5:45 pm
Try using another port as something else on the server may be using port 80 (standard http port).
Also have you allowed SS through your firewall?
Postby weexpectedthis » Mon Mar 12, 2012 6:33 pm
What is SS?
weexpectedthis
Postby bushman4 » Mon Mar 12, 2012 6:39 pm
SubSonic.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby weexpectedthis » Mon Mar 12, 2012 6:41 pm
I guess I'm not sure what "allow SS through your firewall" means. I thought just port forwarding was all that needed to be done.
weexpectedthis
Postby bushman4 » Mon Mar 12, 2012 7:06 pm
On the machine that Subsonic is running on, is there a firewall? Have you opened the port that Subsonic is using on THAT firewall.
Not your router/firewall, a software firewall on your "server."
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby weexpectedthis » Tue Mar 13, 2012 12:47 am
Yes, that Windows 7 machine has a firewall, but even when I completely turn it off, requests to the IP address time out.
weexpectedthis
Postby GJ51 » Tue Mar 13, 2012 3:58 am
Postby weexpectedthis » Tue Mar 13, 2012 2:41 pm
I was able to get it working be jimmying with the firewall settings. Thanks a bunch guys.
weexpectedthis
