Server does not quit on system reboot
Postby werdwerdus » Mon Mar 12, 2012 8:04 pm
Windows XP Professional x64 edition SP1
4.6 (build 2583) – December 6, 2011
jetty-6.1.x, java 1.6.0_31, Windows XP (58.9 MB / 92.9 MB)
When I attempt to restart the computer, the Subsonic Control Panel does not close, preventing the computer from shutting down. I have to manually close the program after the time-out message comes up with "End Now". Is there something I can do to fix the problem?
werdwerdus
Re: Server does not quit on system reboot
Postby pcolline » Sat Sep 22, 2012 4:03 pm
Did you ever find an answer to this? I have the same exact problem. I'm running the latest version of ss (v4.7) but it's been happening with earlier versions too.
pcolline
Postby werdwerdus » Sat Sep 22, 2012 11:03 pm
It doesn't happen any more. I am using build 4.5, I have also updated Java many times. Not sure which one fixed the problem.
werdwerdus
