Samsung Windows App
Samsung Windows App
Postby ldbarthl » Wed Mar 14, 2012 9:35 pm
I purchased the subsonic app for my windows phone running 7.5. and can not get the app to connect to the server. If i login from an android or Iphone it works fine. I have uninstalled the app and reinstalled it. The server is running https, and connecting on port 80. I have tried to connect the windows phone to other subsonic server and it will connect, however they were not https. Is there something i need to do in the clinet for server to get the windows phone to connect using https
thanks
ldbarthl
Re: Samsung Windows App
Postby BKKKPewsey » Wed Mar 14, 2012 11:11 pm
How are you connecting on port 80 using https? that is not a ssl port :?
I would suggest you try to find a forum for the windows app or contact the dev anton@avzuylen.com
