Bug with JAVA 7 ?
Bug with JAVA 7 ?
Postby Jypy » Thu Mar 15, 2012 9:59 am
just to report that there is maybe a bug with subsonic and isub if your server use JAVA 7. You can't play anything, and sometimes the connection fail directly. Tested on iphone 4 and ipad 2 with the last isub version available and subonic 4.6 y 4.7 beta1.
I haven't see anything in the logs and I don't know if it's isub or subonic related, so I will report the bug on both forums.
The web and android player are still working fine.
Thanks for your work.
Jypy
Jypy
Re: Bug with JAVA 7 ?
Postby BKKKPewsey » Thu Mar 15, 2012 1:47 pm
Thank you we are aware.
viewtopic.php?f=2&t=9183#p38878
Postby Jypy » Thu Mar 15, 2012 7:59 pm
Thanks ;)
Jypy
