move subsonic
move subsonic
Postby lb89 » Sat Mar 17, 2012 12:58 pm
Hello i try to move my subsonic server.
From one debian server to a other. The problem is that i can't move my users and settings.
First i install java and subsonic on the new server. After that i stopped the subsonic serverice on the server with my users and settings.
Then i copied the folders /var/subsonic, /usr/share/subsonic, /usr/bin/subsonic and the config file /etc/default/subsonic with SCP. From the old on the new.
But my users and settings are not on the new server. What do i wrong?
I also searched for a tutorial backup / restore subsonic..
Thaks for help!
lb89
Re: move subsonic
Postby BKKKPewsey » Sat Mar 17, 2012 1:46 pm
Not being a Debian user I do not know what you are copying there but the user settings etc are stored in db\subsonic.script file.
Make sure SS is not running on the target server - then copy across the db folder - then restart SS.
Re: move subsonic
Postby lb89 » Sat Mar 17, 2012 3:23 pm
Thanks a lot dude taht worked. :D
I dont know exactly what i first did wrong.. Cause the folder db is in /var/subsonic/db.. Anyway thanks!
lb89
