Android + Network
Android + Network
Postby belette » Sun Mar 18, 2012 11:25 pm
I'am French, sorry language.
Server version : 4.6 (build 2583)
Android version : 3.3
My server is dedicaced server, no local network!
Connection WiFi is OK + playing OK!
Connection 3G is OK + playing impossible (popup : Notice: no network available)
Thank you.
belette
Re: Android + Network
Postby BKKKPewsey » Mon Mar 19, 2012 12:15 am
Check with http://canyouseeme.org that your port is open.
Postby belette » Mon Mar 19, 2012 9:00 am
My port (TCP : 80) is open, my server is dedicated server (http://www.online.net/serveur-dedie/off ... x-sc.xhtml).
Just download music generate error. Listing music, search and playlist is OK.
belette
Postby Ghosterk » Wed Mar 21, 2012 6:50 pm
I have almost the same issue.
My Android app works perfectly when I'm connected through Wifi.
But when I'm using data network, the song doesn't start and the app says "Download 0 b".
The port is open, and I can browse files in the app ; just can't listen music...
Android version : 4.0.3
Phone : I9100 (Samsung Galaxy S II)
Android app version : 3.3
Server version : 4.6 (build 2583) - jetty-6.1.x, java 1.7.0_03, Windows 7 (41.5 MB / 77.0 MB)
OS : Windows 7
There is no specific information in the log except "INFO PlaylistInputStream user listening to "song"".
@belette : In which french telephone company are you ?
Thank you for your help !
Ghosterk
Postby belette » Wed Mar 21, 2012 7:28 pm
Hello Ghosterk,
I'am Free Mobile (http://mobile.free.fr/), It's new operator.
I'have test other mobile (HTC), but even operator, connection and playing it's OK!
My old mobile device it's Motorola Droid (Android 2), identical problem.
Now mobile is Samsung Galaxy S II (Android 4).
My server is Debian, and JAVA software is openjdk-6-jre.
belette
Postby bushman4 » Wed Mar 21, 2012 7:32 pm
Can you have someone on a different phone network try it?
It is possible that your ISP on either side (either the one you use at home or the one that provides internet service to your phone) is filtering traffic based on its content.
You are not using SSL, correct? Turning that on may alleviate the problem, as your ISP would not be able to see inside the packets to see what kind of traffic it is.
I am willing to test from our US Verizon network if you want to set me up a guest account and PM me the login information...
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Ghosterk » Thu Mar 22, 2012 6:12 pm
I'm now using SSL, and it works. I had to use a random port because Google Chrome doesn't want to connect on port 443 without a valid certificate.
Thank you for your help. I hope that it will work for you belette.
PS : My network is provide by Bouygues Telecom.
Ghosterk
