Can't login
Can't login
Postby kb » Wed Oct 03, 2007 5:49 pm
I've just setup Subsonic, and it won't let me login. I use the standard admin/admin username and password, and it says "Wrong username or password."
I looked up similar problems in this forum, and I don't seem to have the problems they're having. My /var/subsonic exists and is writable. The logs for tomcat5.5 and apache2 yield no information.
Where else should I look for my problem? Does tomcat-users.xml have anything to do with this?
I'm using Subsonic v.3.1 running on Ubuntu Edgy. I'm using java-1.5.0-sun-1.5.0.08
Cheers,
-Blake
kb
remove subsonic from webapps
Postby rlefig » Wed Oct 03, 2007 7:36 pm
I would remove any subsonic folders war files and whatever from the webapps directory
rlefig
Try this
Postby linuxman » Wed Oct 03, 2007 7:57 pm
Go to /var/lib/tomcat5/webapps and remove the subsonic folder as well as delete everything in /var/subsonic and then start tomcat5 again and see if that fixes the problem. It should then totally redeploy with no config info and let you do the default login. If not then you might still have some java version issues floating around.
linuxman
fixed
Postby kb » Thu Oct 04, 2007 1:12 pm
That did it, thanks!
By the way, I shut down tomcat before deleting the folders.
kb
Re: Try this
Postby ENFORCER » Tue Oct 16, 2007 2:43 pm
linuxman wrote:Go to /var/lib/tomcat5/webapps and remove the subsonic folder as well as delete everything in /var/subsonic and then start tomcat5 again and see if that fixes the problem. It should then totally redeploy with no config info and let you do the default login. If not then you might still have some java version issues floating around.
I cant find the /var/library..... path anywhere. My install path is C:\Program Files\Apache Software Foundation\Tomcat 5.5
Can anyone help me from there? Or am i in the wrong spot totaly? Man i upgrade to the new version and i feel like a NUBIE all over again! :roll:
ENFORCER
Postby lofty » Tue Oct 16, 2007 4:26 pm
Your right Im sure Var/Lib are for people installing on unix or w/e as I am on win server 2003 and cant see that newhere.
lofty
Postby ENFORCER » Tue Oct 16, 2007 4:52 pm
lofty wrote:Your right Im sure Var/Lib are for people installing on unix or w/e as I am on win server 2003 and cant see that newhere.
Thats all i could come up with as well (that it was a Unix thing).
I feel smart again 8)
ENFORCER
Postby ENFORCER » Tue Oct 16, 2007 5:15 pm
NM my question. I dident have Tomcat properly shutdown when i tried the install and it made a whole heap of problems. Im running on ver 3.2 now and OH HOW SWEET IT IS!!!!!
ENFORCER
