Help with streaming podcasts on Android
Postby SubBurgundy » Thu Mar 22, 2012 7:06 pm
Hello, I am a long time listener first time caller, have used this forum tremendously without registering, and have finally not found an answer to the problem I am having with subsonic (never thought this would happen :p )
So I decided to register here seeing as its such a great community and I really don't see any worthy replacement for what Subsonic does!
The issue I am having is with streaming podcasts to my android phone from my subsonic server. The podcasts stream fine via the web gui player, and through an external player that I have set up, but when attempting to play them on the android app, they will not play, and simply freeze up at the following screen (and never actually download)
My current setup is as follows...
Subsonic Server:
Version 4.6 (build 2585) – December 6, 2011
Server jetty-6.1.x, java 1.6.0_26, Linux (128.8 MB / 223.4 MB)
(OS Linux Mint 12)
I installed using the instructions from the website, am running as root upon start up without any issues, and am able to stream all my music perfectly.
Player Settings:
The only transcode setting I have tested with this is the default for 4.6
mp3 audio
ogg oga aac m4a flac wav wma ape mpc
Step 1
ffmpeg -i %s -ab %bk -v 0 -f mp3 -
I am able to stream all of my podcasts without any issues in all player configurations I have tried except for the Android app, which randomly does not play some of the podcasts.
Subsonic Android App:
Version: 3.3
The actual audio files:
I have tried using Subsonic to manage the podcast feeds, and also an external program as well, and it made no difference the same podcasts where unable to be played regardless of which program handled the feeds. The podcasts are saved in a folder named "Podcast" within my music library, and I can view them all just fine like the rest of my library within the Android app.
The actual files themselves are mostly just voice recordings, with low bitrates, I do not know if that should or would make a difference. I can not exactly pinpoint as to why some of the podcasts work on the android app and some of them do not, yet all of them do from the other players.
The latest output from /var/subsonic/subsonic.log after fialing to stream the file that is pictured above in the screenshot (my username removed)...
[2012-03-22 14:29:33,225] INFO PlaylistInputStream - listening to "AndroidGuys | Blog Talk Radio Feed/androidguys-episode-116.mp3"
[2012-03-22 14:29:51,113] DEBUG AudioScrobblerService - Successfully registered now playing for song 'A' for user at Last.fm.
[2012-03-22 14:31:27,726] INFO PodcastService - Starting scheduled Podcast refresh.
[2012-03-22 14:31:27,727] INFO PodcastService - Completed scheduled Podcast refresh.
[2012-03-22 14:33:06,222] DEBUG AudioScrobblerService - Successfully registered submission for song 'A' for user  at Last.fm.
Has anyone else encountered this? What could it be? What should I try next?
Thanks to anyone for the help.
SubBurgundy
Re: Re: Help with streaming podcasts on Android
Postby paulodell » Thu Mar 22, 2012 7:49 pm
SubBurgundy wrote:Hello, I am a long time listener first time caller, have used this forum tremendously without registering, and have finally not found an answer to the problem I am having with subsonic (never thought this would happen :p )
Subsonic Server:
(OS Linux Mint 12)
Player Settings:
mp3 audio
Step 1
Version: 3.3
Give the transcoder in my signature a try, it encodes all files to mp3 and this seems to help with low bitrate files
Paul
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Postby SubBurgundy » Fri Mar 23, 2012 4:48 am
paulodell wrote:Give the transcoder in my signature a try, it encodes all files to mp3 and this seems to help with low bitrate files
Paul
Will do thank you for the help.. I do not know very much about how to alter the transcode settings (ie what the syntax is/means), any changes I have made in the past were things I dfound on this forum.
EDIT: Well it did not make a difference, nor can I hear any audible difference in the audio, althought these have really low bitrates... out of curiosity however I did check and have come to realize that alll of the podcasts that won't play on android were all below 40 kbps ... coincidence?
SubBurgundy
Postby paulodell » Fri Mar 23, 2012 7:04 am
Can you screenshot what you put into the transcoder with my signature.
Also can you see it re-encoding in the log as you try to play?
With this transcoder the quality does not change it simply re-encodes mp3 to mp3 always.
I don't know why it helps it just seems to work with SubWiji
Cheers
Paul
paulodell
Postby SubBurgundy » Sat Mar 24, 2012 4:54 am
not quite sure what you want in a screen shot, here is your transcode form yout sig placed in my settings, with your sig in another window...
Here is what logs read after trying to play a podcast with that transcode setting set for the android player:
[2012-03-24 00:45:42,043] INFO PlaylistInputStream - Shane listening to "Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3"
[2012-03-24 00:45:42,044] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-f] [mp3] [-i] [/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Aug  9 2011 14:18:27 with gcc 4.5.2
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil    51. 11. 1 / 51. 11. 1
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec   53.  9. 1 / 53.  9. 1
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat  53.  6. 0 / 53.  6. 0
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice  53.  2. 0 / 53.  2. 0
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter   2. 28. 1 /  2. 28. 1
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale    2.  0. 0 /  2.  0. 0
[2012-03-24 00:45:42,049] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2012-03-24 00:45:42,063] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xac3abe0] max_analyze_duration 5000000 reached at 5015510
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xac3abe0] Estimating duration from bitrate, this may be inaccurate
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mp3, from '/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3':
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     title           : T
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     artist          : S
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     album           : BlogTalkRadio.com
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     date            : 2012
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:31:29.10, start: 0.000000, bitrate: 32 kb/s
[2012-03-24 00:45:42,064] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: mp3, 11025 Hz, mono, s16, 32 kb/s
[2012-03-24 00:45:42,075] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, mp3, to 'pipe:':
[2012-03-24 00:45:42,075] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:45:42,075] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TIT2            : T
[2012-03-24 00:45:42,075] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TPE1            : S
[2012-03-24 00:45:42,075] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TALB            : BlogTalkRadio.com
[2012-03-24 00:45:42,075] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TDRL            : 2012
[2012-03-24 00:45:42,075] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:45:42,075] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TSSE            : Lavf53.6.0
[2012-03-24 00:45:42,076] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: libmp3lame, 11025 Hz, mono, s16, 128 kb/s
[2012-03-24 00:45:42,076] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2012-03-24 00:45:42,076] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2012-03-24 00:45:42,076] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[2012-03-24 00:45:50,045] INFO PlaylistInputStream - Shane listening to "Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3"
[2012-03-24 00:45:50,047] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-f] [mp3] [-i] [/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Aug  9 2011 14:18:27 with gcc 4.5.2
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil    51. 11. 1 / 51. 11. 1
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec   53.  9. 1 / 53.  9. 1
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat  53.  6. 0 / 53.  6. 0
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice  53.  2. 0 / 53.  2. 0
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter   2. 28. 1 /  2. 28. 1
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale    2.  0. 0 /  2.  0. 0
[2012-03-24 00:45:50,054] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2012-03-24 00:45:50,082] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xa841be0] max_analyze_duration 5000000 reached at 5015510
[2012-03-24 00:45:50,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xa841be0] Estimating duration from bitrate, this may be inaccurate
[2012-03-24 00:45:50,087] /DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mp3, from '/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3':
[2012-03-24 00:45:50,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:45:50,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     title           : T
[2012-03-24 00:45:50,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     artist          : S
[2012-03-24 00:45:50,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     album           : BlogTalkRadio.com
[2012-03-24 00:45:50,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     date            : 2012
[2012-03-24 00:45:50,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:45:50,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:31:29.10, start: 0.000000, bitrate: 32 kb/s
[2012-03-24 00:45:50,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: mp3, 11025 Hz, mono, s16, 32 kb/s
[2012-03-24 00:45:50,098] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, mp3, to 'pipe:':
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TIT2            : T
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TPE1            : S
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TALB            : BlogTalkRadio.com
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TDRL            : 2012
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TSSE            : Lavf53.6.0
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: libmp3lame, 11025 Hz, mono, s16, 128 kb/s
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2012-03-24 00:45:50,099] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[2012-03-24 00:45:52,054] INFO PlaylistInputStream - Shane listening to "Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3"
[2012-03-24 00:45:52,057] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-f] [mp3] [-i] [/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Aug  9 2011 14:18:27 with gcc 4.5.2
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil    51. 11. 1 / 51. 11. 1
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec   53.  9. 1 / 53.  9. 1
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat  53.  6. 0 / 53.  6. 0
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice  53.  2. 0 / 53.  2. 0
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter   2. 28. 1 /  2. 28. 1
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale    2.  0. 0 /  2.  0. 0
[2012-03-24 00:45:52,074] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2012-03-24 00:45:52,091] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xa00cbe0] max_analyze_duration 5000000 reached at 5015510
[2012-03-24 00:45:52,094] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xa00cbe0] Estimating duration from bitrate, this may be inaccurate
[2012-03-24 00:45:52,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mp3, from '/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3':
[2012-03-24 00:45:52,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:45:52,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     title           : T
[2012-03-24 00:45:52,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     artist          : S
[2012-03-24 00:45:52,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     album           : BlogTalkRadio.com
[2012-03-24 00:45:52,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     date            : 2012
[2012-03-24 00:45:52,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:45:52,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:31:29.10, start: 0.000000, bitrate: 32 kb/s
[2012-03-24 00:45:52,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: mp3, 11025 Hz, mono, s16, 32 kb/s
[2012-03-24 00:45:52,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, mp3, to 'pipe:':
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TIT2            : T
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TPE1            : S
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TALB            : BlogTalkRadio.com
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TDRL            : 2012
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TSSE            : Lavf53.6.0
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: libmp3lame, 11025 Hz, mono, s16, 128 kb/s
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2012-03-24 00:45:52,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[2012-03-24 00:45:57,147] INFO PlaylistInputStream - Shane listening to "Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3"
[2012-03-24 00:45:57,159] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-f] [mp3] [-i] [/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[2012-03-24 00:45:57,204] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[2012-03-24 00:45:57,204] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Aug  9 2011 14:18:27 with gcc 4.5.2
[2012-03-24 00:45:57,204] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[2012-03-24 00:45:57,204] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil    51. 11. 1 / 51. 11. 1
[2012-03-24 00:45:57,204] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec   53.  9. 1 / 53.  9. 1
[2012-03-24 00:45:57,204] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat  53.  6. 0 / 53.  6. 0
[2012-03-24 00:45:57,204] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice  53.  2. 0 / 53.  2. 0
[2012-03-24 00:45:57,204] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter   2. 28. 1 /  2. 28. 1
[2012-03-24 00:45:57,205] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale    2.  0. 0 /  2.  0. 0
[2012-03-24 00:45:57,205] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2012-03-24 00:45:57,297] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xa675be0] max_analyze_duration 5000000 reached at 5015510
[2012-03-24 00:45:57,313] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xa675be0] Estimating duration from bitrate, this may be inaccurate
[2012-03-24 00:45:57,313] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mp3, from '/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3':
[2012-03-24 00:45:57,314] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:45:57,314] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     title           : T
[2012-03-24 00:45:57,314] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     artist          : S
[2012-03-24 00:45:57,314] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     album           : BlogTalkRadio.com
[2012-03-24 00:45:57,314] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     date            : 2012
[2012-03-24 00:45:57,314] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:45:57,314] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:31:29.10, start: 0.000000, bitrate: 32 kb/s
[2012-03-24 00:45:57,314] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: mp3, 11025 Hz, mono, s16, 32 kb/s
[2012-03-24 00:45:57,393] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, mp3, to 'pipe:':
[2012-03-24 00:45:57,396] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:45:57,397] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TIT2            : T
[2012-03-24 00:45:57,397] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TPE1            : S
[2012-03-24 00:45:57,397] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TALB            : BlogTalkRadio.com
[2012-03-24 00:45:57,397] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TDRL            : 2012
[2012-03-24 00:45:57,397] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:45:57,397] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TSSE            : Lavf53.6.0
[2012-03-24 00:45:57,398] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: libmp3lame, 11025 Hz, mono, s16, 128 kb/s
[2012-03-24 00:45:57,398] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2012-03-24 00:45:57,398] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2012-03-24 00:45:57,399] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[2012-03-24 00:46:02,085] INFO PlaylistInputStream - Shane listening to "Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3"
[2012-03-24 00:46:02,087] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-f] [mp3] [-i] [/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[2012-03-24 00:46:02,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[2012-03-24 00:46:02,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Aug  9 2011 14:18:27 with gcc 4.5.2
[2012-03-24 00:46:02,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[2012-03-24 00:46:02,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil    51. 11. 1 / 51. 11. 1
[2012-03-24 00:46:02,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec   53.  9. 1 / 53.  9. 1
[2012-03-24 00:46:02,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat  53.  6. 0 / 53.  6. 0
[2012-03-24 00:46:02,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice  53.  2. 0 / 53.  2. 0
[2012-03-24 00:46:02,096] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter   2. 28. 1 /  2. 28. 1
[2012-03-24 00:46:02,096] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale    2.  0. 0 /  2.  0. 0
[2012-03-24 00:46:02,096] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2012-03-24 00:46:02,106] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0x9cf0be0] max_analyze_duration 5000000 reached at 5015510
[2012-03-24 00:46:02,106] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0x9cf0be0] Estimating duration from bitrate, this may be inaccurate
[2012-03-24 00:46:02,106] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mp3, from '/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3':
[2012-03-24 00:46:02,107] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:46:02,107] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     title           : T
[2012-03-24 00:46:02,107] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     artist          : S
[2012-03-24 00:46:02,107] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     album           : BlogTalkRadio.com
[2012-03-24 00:46:02,107] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     date            : 2012
[2012-03-24 00:46:02,107] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:46:02,107] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:31:29.10, start: 0.000000, bitrate: 32 kb/s
[2012-03-24 00:46:02,107] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: mp3, 11025 Hz, mono, s16, 32 kb/s
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, mp3, to 'pipe:':
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TIT2            : T
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TPE1            : S
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TALB            : BlogTalkRadio.com
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TDRL            : 2012
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TSSE            : Lavf53.6.0
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: libmp3lame, 11025 Hz, mono, s16, 128 kb/s
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2012-03-24 00:46:02,117] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[2012-03-24 00:46:07,123] INFO PlaylistInputStream - Shane listening to "Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3"
[2012-03-24 00:46:07,126] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-f] [mp3] [-i] [/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[2012-03-24 00:46:07,184] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[2012-03-24 00:46:07,185] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Aug  9 2011 14:18:27 with gcc 4.5.2
[2012-03-24 00:46:07,185] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[2012-03-24 00:46:07,192] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil    51. 11. 1 / 51. 11. 1
[2012-03-24 00:46:07,192] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec   53.  9. 1 / 53.  9. 1
[2012-03-24 00:46:07,192] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat  53.  6. 0 / 53.  6. 0
[2012-03-24 00:46:07,193] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice  53.  2. 0 / 53.  2. 0
[2012-03-24 00:46:07,193] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter   2. 28. 1 /  2. 28. 1
[2012-03-24 00:46:07,193] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale    2.  0. 0 /  2.  0. 0
[2012-03-24 00:46:07,193] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2012-03-24 00:46:07,270] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xa988be0] max_analyze_duration 5000000 reached at 5015510
[2012-03-24 00:46:07,289] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0xa988be0] Estimating duration from bitrate, this may be inaccurate
[2012-03-24 00:46:07,289] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mp3, from '/media/Music/Podcast/Steve Turano | Blog Talk Radio Feed/the-truth-about-weight-loss-fitness.mp3':
[2012-03-24 00:46:07,289] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:46:07,289] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     title           : T
[2012-03-24 00:46:07,289] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     artist          : S
[2012-03-24 00:46:07,290] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     album           : BlogTalkRadio.com
[2012-03-24 00:46:07,290] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     date            : 2012
[2012-03-24 00:46:07,290] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:46:07,290] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:31:29.10, start: 0.000000, bitrate: 32 kb/s
[2012-03-24 00:46:07,290] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: mp3, 11025 Hz, mono, s16, 32 kb/s
[2012-03-24 00:46:07,349] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, mp3, to 'pipe:':
[2012-03-24 00:46:07,354] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2012-03-24 00:46:07,354] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TIT2            : T
[2012-03-24 00:46:07,357] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TPE1            : S
[2012-03-24 00:46:07,366] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TALB            : BlogTalkRadio.com
[2012-03-24 00:46:07,367] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TDRL            : 2012
[2012-03-24 00:46:07,367] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     comment         :
[2012-03-24 00:46:07,367] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TSSE            : Lavf53.6.0
[2012-03-24 00:46:07,367] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: libmp3lame, 11025 Hz, mono, s16, 128 kb/s
[2012-03-24 00:46:07,367] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2012-03-24 00:46:07,367] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2012-03-24 00:46:07,367] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
Again, I do not fully understand the syntax or cmmds for cli of the transcoding of different formats/codecs, so I do not fully understand what the logs actually mean went wrong.
SubBurgundy
