How to install a Mod?
Postby quatermass » Fri Mar 23, 2012 11:57 am
I'm running 4.6 (build 2583) – 06 December 2011 on a Windows 7 Pro SP1 32bit quad core PC and it's working fine.
But recently I wanted to enhance the video output by adding the Videoplayer Aspect Ratio Mod.
But it gives no complete instructions on how to do this.
I tried looking in other Mods to see how they do it and it appears I'm suppose to have a webapp folder inside the root subsonic folder. Well I don't have that.
The only folder I have in there is c:\subsonic\logs
I've tried a full system search and its not on my PC.
I suspect I'm missing something which is obvious to others? :D
Stuart Halliday
The Computer Man
quatermass
Re: How to install a Mod?
Postby BKKKPewsey » Fri Mar 23, 2012 2:51 pm
Not sure what you are looking at but there isn't a folder called logs in c:\subsonic :?
The folder you are looking for is in c:\subsonic\jetty\xxxx\webapp
Postby quatermass » Fri Mar 23, 2012 3:01 pm
Opps I meant 'log'.
I have just this. See attachment.
Stuart Halliday
The Computer Man
quatermass
Postby BKKKPewsey » Fri Mar 23, 2012 3:08 pm
That is not the c:\subsonic folder but your C:\Program Files\Subsonic\ folder - eg wrong one :D
The folder you want is the working folder eg: c:\subsonic not the installation directory.
Postby quatermass » Fri Mar 23, 2012 4:52 pm
Ah.. I see my confusion clearing.
I've actually got a F:\ drive with my OS and subsonic on it. No 'f:\Program Files\Subsonic' here
So Subsonic is in f:\subsonic as far as I was aware.
After trawling my whole PC for 'subsonic'. I see my little used DATA c:\ drive has a subsonic folder in it.
It would appear to have some of the folders I need in there. Bizarre.
I appear to need to put my Mod into the c:\subsonic\webapp folder but that's not there either.
Thanks. For helping me out, looks like this Mod may be out of date with the recent version of Subsonic?
Stuart Halliday
The Computer Man
quatermass
Postby BKKKPewsey » Fri Mar 23, 2012 6:08 pm
quatermass wrote:I appear to need to put my Mod into the c:\subsonic\webapp folder but that's not there either.
BKKKPewsey wrote:The folder you are looking for is in c:\subsonic\jetty\xxxx\webapp
Postby quatermass » Sat Mar 24, 2012 1:00 pm
Thanks for that. :D
Easy if you know of course.
Why don't mod'ers put this in their install instructions or in the FAQ I wonder? :?:
Stuart Halliday
The Computer Man
quatermass
Users browsing this forum: No registered users and 44 guests
