Subsonic finds only a few media folders [solved]
Postby Ununnilium » Tue Mar 27, 2012 2:07 pm
I have installed Subsonic 4.6 (build 2583) on a Debian server with Tomcat (Apache Tomcat/6.0.35, java 1.6.0_18, Linux (90,1 MB / 127,2 MB)). My problem is that Subsonic doesn't use all the media folders i have specified:
The file permissions should be okay:
drwxrwxrwx 216 tomcat6 tomcat6 12288 27. Mär 15:00 Filme
drwxrwxrwx  20 tomcat6 tomcat6  4096 27. Mär 15:00 Serien
In the log there is nothing special:
[27.03.12 15:29:41 MESZ]   INFO   VersionService   Resolved latest Subsonic beta version to: 4.6.beta2
[27.03.12 15:30:29 MESZ]   INFO   SecurityService   Created user test
[27.03.12 15:30:38 MESZ]   INFO   PlayerDao   Created player 2.
[27.03.12 15:34:33 MESZ]   INFO   PodcastService   Starting scheduled Podcast refresh.
[27.03.12 15:34:33 MESZ]   INFO   PodcastService   Completed scheduled Podcast refresh.
[27.03.12 15:37:58 MESZ]   INFO   MusicFolderDao   Deleted music folder with ID 10
[27.03.12 15:37:58 MESZ]   INFO   MusicFolderDao   Deleted music folder with ID 11
[27.03.12 15:38:02 MESZ]   INFO   MusicFolderDao   Created music folder /daten/daten/Videos
[27.03.12 15:50:33 MESZ]   INFO   MusicFolderDao   Created music folder /daten/daten/Videos/Filme
[27.03.12 15:50:45 MESZ]   INFO   MusicFolderDao   Created music folder /daten/daten/Videos/Serien
I have already restarted the Tomcat server and deleted/recreated the folder entry in Subsonic.
Thanking you in anticipation.
Ununnilium
Re: Subsonic finds only a few media folders
Postby Ununnilium » Tue Mar 27, 2012 4:09 pm
The problem is solved. I have deleted all files from /var/subsonic and the Subsonic files in the Tomcat directory and then reinstalled the .war file. I think there was probably a problem with the old configuration.
Ununnilium
