Play entire folder?
Play entire folder?
Postby Cr0n_J0b » Sun Apr 01, 2012 11:32 pm
Hi everyone,
I'm sure this is a simple stupid question, but I'm brand new to Subsonic and don't really have a clue about how things work yet.
I'm trying to just have it look in a directory called say 2011, which has several other folders in it. I want it to play everything in that directoy in random order so that I can listen to it like an internet radio station. will that work?
Can I then setup another "channel" with another folder to play at the same time?
thanks
Cr0n_J0b
Re: Play entire folder?
Postby BKKKPewsey » Mon Apr 02, 2012 1:46 am
If you your folder "2011" as root media folder into subsonic you can then create/play a random playlist just using that folder.
You can create another stream by logging on as another user
Postby mdeeter » Fri May 11, 2012 6:01 pm
I agree that it seems weird that I can use the app to select all songs... and event add them to a playlist.... just not my current playlist. Seems like a missing feature.
mdeeter
