Help with jukebox mode on linux
Postby nightwulf » Fri Apr 06, 2012 4:21 am
Hello. I'm having quite a time with jukebox mode on my server. The web player works fine, as does the Android app, for playing through other devices. I can't get anything out of jukebox mode. There is no visible error reported. I've tried via the web and Android player. Once playback is started, the transcoding appears to be in progress:
username@server:/var/subsonic# ps x | grep ffmpeg
26030 pts/2    S      0:00 /var/subsonic/transcode/ffmpeg -ss 0 -i /home/username/shared/audio/The Smashing Pumpkins/[1993] Siamese Dream/01- Cherub Rock.flac -v 0 -f au -
I can't find this transcoding anywhere in the settings. Is it hard-coded for use in jukebox mode? I've tried changing the transcoding for the jukebox player (using suggestions from the Transcoders page on the wiki), but regardless of what transcoders I enter and associate with the player, I always get the ffmpeg line shown above.
I compiled audioDevList and have tried every line in subsonic.sh with the same results (no playback). Interestingly, I installed the Windows version on XP Professional running in VirtualBox on the same machine, and jukebox mode works perfectly.
Playback Application and version: web player and Android app v3.3.
Subsonic Version: 4.6 (build 2583) – December 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_25, Linux (24.8 MB / 88.9 MB)
Hardware Platform: Slackware 13.37 - Linux (servername) 2.6.37.6 #3 SMP Sat Apr 9 22:49:32 CDT 2011 x86_64 AMD Phenom(tm) II X4 945 Processor AuthenticAMD GNU/Linux
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar) n/a, linux
Problem Filename: Really all of them, but as an example: 01- Cherub Rock.flac
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
> /var/subsonic/transcode/ffmpeg -i ./01-*
ffmpeg version 0.10 Copyright (c) 2000-2012 the FFmpeg developers
  built on Mar 16 2012 16:12:54 with gcc 4.5.2
  configuration: --enable-libmp3lame
  libavutil      51. 34.101 / 51. 34.101
  libavcodec     53. 60.100 / 53. 60.100
  libavformat    53. 31.100 / 53. 31.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 60.100 /  2. 60.100
  libswscale      2.  1.100 /  2.  1.100
  libswresample   0.  6.100 /  0.  6.100
[flac @ 0x13d83a0] max_analyze_duration 5000000 reached at 5015510
Input #0, flac, from './01- Cherub Rock.flac':
  Metadata:
    ENSEMBLE        : The Smashing Pumpkins
    TITLE           : Cherub Rock
    ARTIST          : The Smashing Pumpkins
    ALBUM           : Siamese Dream
    COMMENT         : Track 1
    track           : 01
    DATE            : 1993
    ALBUM ARTIST    : The Smashing Pumpkins
    DISC            : 1
    album_artist    : The Smashing Pumpkins
    TOTALTRACKS     : 13
  Duration: 00:04:57.97, bitrate: 913 kb/s
    Stream #0:0: Audio: flac, 44100 Hz, stereo, s16
Last ten log file lines: (The last ten or so lines copied and pasted from the About screen in the Subsonic Web Interface. Ideally these will be in a CODE block as well.)
[4/5/12 11:08:00 PM CDT]    INFO   DaoHelper   Checking database schema.
[4/5/12 11:08:00 PM CDT]    INFO   DaoHelper   Done checking database schema.
[4/5/12 11:08:00 PM CDT]    INFO   SearchService   Automatic index creation scheduled to run every 1 day(s), starting at Fri Apr 06 03:00:00 CDT 2012
[4/5/12 11:08:00 PM CDT]    INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu Apr 05 23:13:00 CDT 2012
[4/5/12 11:08:03 PM CDT]    INFO   NetworkService   Deleted port mapping for port (myPortNumber)
[4/5/12 11:08:06 PM CDT]    INFO   VersionService   Resolved local Subsonic version to: 4.6
[4/5/12 11:08:06 PM CDT]    INFO   VersionService   Resolved latest Subsonic final version to: 4.6
[4/5/12 11:08:06 PM CDT]    INFO   VersionService   Resolved latest Subsonic beta version to: 4.6.beta2
[4/5/12 11:08:12 PM CDT]    DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/home/username/shared/audio/The Smashing Pumpkins/[1993] Siamese Dream/01- Cherub Rock.flac] [-v] [0] [-f] [au] [-]
[4/5/12 11:08:12 PM CDT]    DEBUG   JukeboxService   Opened line com.sun.media.sound.DirectAudioDevice$DirectSDL@26b98a06
[4/5/12 11:08:12 PM CDT]    INFO   JukeboxService   admin starting jukebox for "[1993] Siamese Dream/01- Cherub Rock.flac"
Thanks much in advance.
nightwulf
Re: Help with jukebox mode on linux
Postby BKKKPewsey » Fri Apr 06, 2012 9:49 pm
Have you read viewtopic.php?f=2&t=8534
It may help
Postby nightwulf » Sun Apr 08, 2012 5:49 pm
I did come across that thread in searching for posts regarding the same error, but I'm not getting any error message in the log nor is PulseAudio installed.
nightwulf
