Can't play video
Can't play video
Postby bobby2682 » Sat Apr 07, 2012 5:49 pm
Problem Description: I am using windows 7 and have and android (samsung gallaxy SII) it supports flash. I can stream audio with no problems but but video doest show up at all. I set a folder for my video files and when I bring that folder up on my phone nothing shows up. If I bring subsonic up in web browser I can see my video files but when I try to play them through the web browser I get an error that says
"video not found or access denied: /stream?pathUtf8Hex=463a5c48444d6f766965735c596f75722e4869676863657
3732e426c757261792e31303830702e783236342e6d6b76&maxBitRate=1000&
timeOffset=0&player=1"
Troubleshooting Steps: None I don't no where to start
Playback Application and version: Subsonic Web Player
Subsonic Version: 4.6 (build 2583) – December 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_31, Windows 7 (71.0 MB / 96.7 MB)
Hardware Platform: Windows 7
Java Memory Limit: I dont know where to find this
Problem Filename: All Video
Output from ffmpeg -i: I tried this but it sas ffmpeg is not recognized as an internal or external comapnd
Last ten log file lines: See below
Subsonic log:
[4/7/12 1:55:51 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Duration: 01:33:19.33, start: 0.000000, bitrate: N/A
[4/7/12 1:55:51 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.0: Video: h264, yuv420p, 1920x816, PAR 1:1 DAR 40:17, 47.62 fps, 25 tbr, 1k tbn, 47.95 tbc
[4/7/12 1:55:51 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.1: Audio: dca, 48000 Hz, 6 channels, s16
[4/7/12 1:55:51 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.2(dut): Subtitle: 0x0000
[4/7/12 1:55:51 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.3(eng): Subtitle: 0x0000
[4/7/12 1:55:51 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) c:\subsonic\transcode\ffmpeg: unrecognized option 'preset'
[4/7/12 1:55:59 PM EDT] INFO PlaylistInputStream admin listening to "HDMovies\13.Thirteen.2010.BluRay.1080p.DTS.x264.mkv"
[4/7/12 1:55:59 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [F:\HDMovies\13.Thirteen.2010.BluRay.1080p.DTS.x264.mkv] [-async] [1] [-b] [5000k] [-s] [1130x480] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavutil 50. 7. 0 / 50. 7. 0
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavcodec 52.47. 0 / 52.47. 0
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavformat 52.47. 0 / 52.47. 0
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavfilter 1.15. 0 / 1.15. 0
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libswscale 0. 8. 0 / 0. 8. 0
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [matroska @ 0144ee90]MAX_READ_SIZE:5000000 reached
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [matroska @ 0144ee90]Estimating duration from bitrate, this may be inaccurate
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 25.00 (25/1)
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Input #0, matroska, from 'F:\HDMovies\13.Thirteen.2010.BluRay.1080p.DTS.x264.mkv':
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Duration: 01:33:19.33, start: 0.000000, bitrate: N/A
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.0: Video: h264, yuv420p, 1920x816, PAR 1:1 DAR 40:17, 47.62 fps, 25 tbr, 1k tbn, 47.95 tbc
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.1: Audio: dca, 48000 Hz, 6 channels, s16
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.2(dut): Subtitle: 0x0000
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.3(eng): Subtitle: 0x0000
[4/7/12 1:55:59 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) c:\subsonic\transcode\ffmpeg: unrecognized option 'preset'
[4/7/12 1:56:00 PM EDT] INFO PlaylistInputStream admin listening to "HDMovies\13.Thirteen.2010.BluRay.1080p.DTS.x264.mkv"
[4/7/12 1:56:00 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [F:\HDMovies\13.Thirteen.2010.BluRay.1080p.DTS.x264.mkv] [-async] [1] [-b] [5000k] [-s] [1130x480] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavutil 50. 7. 0 / 50. 7. 0
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavcodec 52.47. 0 / 52.47. 0
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavformat 52.47. 0 / 52.47. 0
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavfilter 1.15. 0 / 1.15. 0
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libswscale 0. 8. 0 / 0. 8. 0
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [matroska @ 0143ee90]MAX_READ_SIZE:5000000 reached
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [matroska @ 0143ee90]Estimating duration from bitrate, this may be inaccurate
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 25.00 (25/1)
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Input #0, matroska, from 'F:\HDMovies\13.Thirteen.2010.BluRay.1080p.DTS.x264.mkv':
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Duration: 01:33:19.33, start: 0.000000, bitrate: N/A
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.0: Video: h264, yuv420p, 1920x816, PAR 1:1 DAR 40:17, 47.62 fps, 25 tbr, 1k tbn, 47.95 tbc
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.1: Audio: dca, 48000 Hz, 6 channels, s16
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.2(dut): Subtitle: 0x0000
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.3(eng): Subtitle: 0x0000
[4/7/12 1:56:00 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) c:\subsonic\transcode\ffmpeg: unrecognized option 'preset'
Any help would be appreciated, I would love to be able to stream video to my phone.
bobby2682
Re: Can't play video
Postby GJ51 » Sun Apr 08, 2012 12:45 am
I'm in the process of investigating the problem on my sites. I think it may be due to the last Java update.
Postby MadEvil » Tue Apr 10, 2012 1:03 pm
you use an very old version of ffmpeg, did you try a newer Version of ffmpeg for transcoding?
Latest Zeranoe FFmpeg Builds Version: git-6bfb304 (2012-04-09)
libavutil      51. 46.100 / 51. 46.100
libavcodec     54. 14.101 / 54. 14.101
libavformat    54.  3.100 / 54.  3.100
libavdevice    53.  4.100 / 53.  4.100
libavfilter     2. 67.101 /  2. 67.101
libswscale      2.  1.100 /  2.  1.100
libswresample   0. 10.100 /  0. 10.100
libpostproc    52.  0.100 / 52.  0.100
Download -> http://ffmpeg.zeranoe.com/builds
Best regards
Madsonic Developer
MadEvil
