external Player and empty play.m3u [Resolved]
Postby Tny » Thu Apr 12, 2012 1:55 pm
Problem Description: If i try to tell subsonic to use an external player (with or without playlist control) and with or without transcoding the player will not start. After inspecting the play.m3u file with firebug it seems to be empty. Music and Video does not work with an external player. Internal player works without problems.
Troubleshooting Steps: raised memory limit for the java process to 256MB, restartet subsonic several times, tried nearly all possible settings in the player settings.
Playback Application and version: none
Subsonic Version: 4.6 (build 2585) – 6. Dezember 2011
Server Version: jetty-6.1.x, java 1.6.0_24, Linux (29,1 MB / 68,0 MB)
Software Platform: Debian sid
Java Memory Limit: 256 MB
Output from ffmpeg -v:
ffmpeg version 0.8.1-4:0.8.1-1, Copyright (c) 2000-2011 the Libav developers
  built on Mar 19 2012 08:42:27 with gcc 4.6.3
This program is not developed anymore and is only provided for compatibility. Use avconv instead (see Changelog for the list of incompatible changes).
ffmpeg 0.8.1-4:0.8.1-1
libavutil    51. 22. 1 / 51. 22. 1
libavcodec   53. 35. 0 / 53. 35. 0
libavformat  53. 21. 0 / 53. 21. 0
libavdevice  53.  2. 0 / 53.  2. 0
libavfilter   2. 15. 0 /  2. 15. 0
libswscale    2.  1. 0 /  2.  1. 0
libpostproc  52.  0. 0 / 52.  0. 0
Last ten log file lines: No Log lines are generated while accessing the .m3u File. Only log lines from transcoding when using the internal player.
Tny
Re: external Player and empty play.m3u
Postby BKKKPewsey » Thu Apr 12, 2012 2:48 pm
Tny wrote:After inspecting the play.m3u file with firebug
Why? it should be a standard m3u files saved on your computer and can be inspected via a normal text editor.
What browser are you using ?
Postby Tny » Fri Apr 13, 2012 8:15 am
Because the m3u file is handled by a browser plugin and no download window opens. So the simplest way (without fiddling with plugin settings) is to use firebug and take a closer look what is coming from the server. And there is only an empty file coming from the server.
But now, i dont know why, it works. Is it possible that the nightly search update run has something to do with it?
Tny
Users browsing this forum: No registered users and 44 guests
