Album Art Disappears
Postby pir8radio » Mon Apr 23, 2012 10:54 pm
On IE9 album art will pop up for a second that go blank... Compatibility mode fixes this.. But what is the the problem that you need to turn compatability mode on?
pir8radio
Re: Album Art Disappears
Postby ytechie » Mon Apr 23, 2012 11:18 pm
This has been a problem with IE for a while. Not sure what causes it, but also not sure why you're using IE. ;)
ytechie
Postby MadEvil » Mon Apr 23, 2012 11:55 pm
pir8radio wrote:On IE9 album art will pop up for a second that go blank... Compatibility mode fixes this.. But what is the the problem that you need to turn compatability mode on?
this is fixed with the final or beta 2 of subsonic 4.7 (no release date now), meanwhile you can use this mod (viewtopic.php?f=8&t=9187)
replaced scriptaculous.js opacity effects with jquery-1.7.1.min.js
best regards
Madsonic Developer
MadEvil
Postby pir8radio » Tue Apr 24, 2012 12:15 am
ahh sweet.... I switch between IE and Chrome... IE is no where near as bad as it used to be... firefox fell off my radar... Either way i was just curious should my other users login via IE...
Thanks guys...
pir8radio
