Some songs wont play...
Postby greenleaved » Fri Apr 27, 2012 6:38 pm
I use subsonic on my galaxy nexus and have my home computer as my sever..sometimes I will set up an album to play and it will download the tracks normally but when it comes to play tracks it will just stop and refuse to play...the file will show its downloaded enough or the entire track, but the yellow pause button that shows when a track is playing turns to a green play button. If I hit play it will not play, and revert back to the green play button.
If I reboot my phone it will.sometimes.fix it and the track will play, but chances are it will do the same thing with another track. I can also just skip that track and normally the next one will play no problem. Sometimes this happens multiple times on one album or playlist. It seems to be random and an issue with the software and not any particular track. All files are mp3s. Please let me know any info you think would be helpful. Thanks.
greenleaved
Re: Some songs wont play...
Postby greenleaved » Fri Apr 27, 2012 6:46 pm
Playback Application and version: Android Subsonic App, version 3.3
Subsonic Version: 4.6 (build 2583) – December 6, 2011
Server Version: jetty-6.1.x, java 1.7.0_02, Windows XP (62.4 MB / 96.7 MB)
Hardware Platform: Windows XP
Java Memory Limit: 100MB
Last ten log file lines:
[4/27/12 3:00:04 AM EDT] INFO SearchService Created search index with 6000 entries.
[4/27/12 3:00:05 AM EDT] INFO SearchService Created search index with 7000 entries.
[4/27/12 3:00:05 AM EDT] INFO SearchService Created search index with 8000 entries.
[4/27/12 3:00:06 AM EDT] INFO SearchService Created search index with 9000 entries.
[4/27/12 3:00:07 AM EDT] INFO SearchService Created search index with 10000 entries.
[4/27/12 3:00:08 AM EDT] INFO SearchService Created search index with 11000 entries.
[4/27/12 3:00:08 AM EDT] INFO SearchService Created search index with 12000 entries.
[4/27/12 3:00:09 AM EDT] INFO SearchService Created search index with 13000 entries.
[4/27/12 3:00:10 AM EDT] INFO SearchService Created search index with 14000 entries.
[4/27/12 3:00:10 AM EDT] INFO SearchService Created search index with 15000 entries.
[4/27/12 3:00:11 AM EDT] INFO SearchService Created search index with 16000 entries.
[4/27/12 3:00:12 AM EDT] INFO SearchService Created search index with 17000 entries.
[4/27/12 3:00:13 AM EDT] INFO SearchService Created search index with 18000 entries.
[4/27/12 3:00:13 AM EDT] INFO SearchService Created search index with 19000 entries.
[4/27/12 3:00:14 AM EDT] INFO SearchService Created search index with 20000 entries.
[4/27/12 3:00:15 AM EDT] INFO SearchService Created search index with 21000 entries.
[4/27/12 3:00:16 AM EDT] INFO SearchService Created search index with 22000 entries.
[4/27/12 3:00:17 AM EDT] INFO SearchService Updating Lucene search index.
greenleaved
Postby bushman4 » Fri Apr 27, 2012 6:49 pm
Try to play one of the songs in question. Does the log change?
What you posted is the normal process of subsonic reindexing its search index.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby greenleaved » Fri Apr 27, 2012 6:51 pm
Last night I was trying to play an album on my phone...it downloaded...then wouldn't play the track. I tried now, and it plays the album fine. It really seems to be random and an issue with the Android app and not my server on my computer, but I don't know.
greenleaved
Postby GJ51 » Sun Apr 29, 2012 4:57 am
I'm seeing a few quircks on my sites when trying to use my Android phone. I transcode my mobile audio to ogg and everything works fine except if I try to replay a downloaded cached track in a new session. If I then delete the cached tracks and replay the album it works fine. I'm not sure but I first started to notice it around the same time the last java update rolled out. Time for more testing.
