How to import WMP Playlists?
Postby Al13NCRY » Sun May 06, 2012 6:42 pm
Hi Guys,
I´m really fascinated about Subsonic. It works perfectly!! Good Job!! (I use it with android and pc)
But there is one little problem I have ...
I try to import a wmp playlist, but it doesn´t open when i click load in subsonic/localhost . I saved the playlist as ".m3u" .
So I tried to open the playlist i made with subsonic with wmp (wich actually works) and saved it with wmp (same name / overwrote it),
after this it didn´t work, too.
I opened both playlists (i made two with the same songs, one saved with subsonic and one saved with wmp ; both as ".m3u") with editor/notepad
Subsonic:
#EXTM3U
C:\Users\MYNAME\Music\8Bit\10800 Zombies Theme.mp3
C:\Users\MYNAME\Music\8Bit\The Super Mario Song.mp3
WMP:
#EXTM3U
#EXTINF:0,10800 Zombies Theme.mp3
..\Users\MYNAME\Music\8Bit\10800 Zombies Theme.mp3
#EXTINF:0,The Super Mario Song.mp3
..\Users\MYNAME\Music\8Bit\The Super Mario Song.mp3
Is there any possibility to import the wmp playlist without changing the code?
Maybe another playlist format? I tried ".pls" but this didn´t work with both players.
AL13NCRY
PS: After changing the code wmp read it as normal playlist ... it worked with both players.
PPS: I´m using Windows 7 and i´m admin (in subsonic, too)
Al13NCRY
Re: How to export WMP Playlists?
Postby hakko » Sun May 06, 2012 7:09 pm
This is a relative search path. I'd say the easiest thing to do if you need to import a playlist like this into Subsonic is open it with Notepad, and search/replace ".." with "C:" (in this case).
MusicCabinet developer
hakko
Postby GJ51 » Sun May 06, 2012 7:28 pm
Playlist Import/Export is on the todo list for being added as a feature in a future release.
Postby Al13NCRY » Sun May 06, 2012 10:08 pm
Yes i did this thing as i said, but this changing of code is too much work.i mean changing the code for almost 100 songs
Is a big job .
When will the future update for impot\export playlists come?
Maybe i can write some program that changes the code ... Let's see ...
But thanks for your help :D
Al13NCRY
Re: How to import WMP Playlists?
Postby BKKKPewsey » Sun May 06, 2012 11:54 pm
Al13NCRY wrote:Yes i did this thing as i said, but this changing of code is too much work.i mean changing the code for almost 100 songs
Is a big job .
A decent text editor will do that in one hit "search and replace all" - done
Postby hakko » Mon May 07, 2012 5:08 am
Even Notepad has an automatic search/replace nowadays. Open your WMP playlist, press Ctrl+H, and use the "Replace all" button. You'll have a working playlist within seconds.
hakko
Postby Al13NCRY » Mon May 07, 2012 4:20 pm
Oh sorry i thought i have to delete the red things, but i only can´t read ".."
#EXTM3U
Thanks for help
:D
Al13NCRY
