Settings to save before reinstall
Postby p2ranger » Sun May 06, 2012 9:29 pm
I'm going to be re installing my ubuntu server which has my subsonic server on it. I would like to be able to save my playlists, users, settings, recently added music, etc information for the new install. I found this topic
http://forum.subsonic.org/forum/viewtopic.php?f=2&t=8980&p=37617&hilit=reinstall#p37611
Just wanted to make sure that what I needed to save is:
1. subsonic.script in /var/subsonic/db
2. subsonic.properties in /var/subsonic
Of course this is after stopping subsonic
Then after reinstalling with latest subsonic (i'm currently at 4.3), stop subsonic, copy those two files, start subsonic, start indexing.
Is that it?
Jason
Subsonic 5.3
Ubuntu 14.04
p2ranger
Re: Settings to save before reinstall
Postby BKKKPewsey » Sun May 06, 2012 11:50 pm
I would take a backup of the whole \subsonic folder just in case - you may need the database files for the recently added list :?
All the other settings are in the files mentioned. (playlists are in their own folder so np)
Postby supra92 » Wed May 16, 2012 3:01 am
Seconded BKKKP's point about, at bare minimum, saving the entire /var/subsonic/db folder -- that'll have all your recent adds and most played info, along with any album reviews you've written and ratings you've assigned.
I haven't had to redo the sever here in a long while, but when I do I always save the entire /var/subsonic directory structure out of sheer safety. Once the new box is up and running, I'll start by copying over the /var/subsonic/db directory along with the /var/subsonic/subsonic.properties file, and then fire things up with the new Subsonic. If anything looks amiss, I still have all the other old files left if needed. They've never been needed :-)
Supra92
supra92
Postby p2ranger » Wed May 16, 2012 5:02 am
Thanks for all the help!
Subsonic 5.3
Ubuntu 14.04
p2ranger
