Exception org.springframework.jdbc.CannotGetJdbcConnectionEx
Postby eivindcom » Sun Oct 21, 2007 4:15 pm
Any help with this?
I have restarted tomcat, and reinstalled subsonic, no luck.
Error
Exception org.springframework.jdbc.CannotGetJdbcConnectionException
Message Could not get JDBC Connection; nested exception is java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@72a11e14[file =C:\subsonic\db\subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: The process cannot access the file because another process has locked a portion of the file : C:\subsonic\db\subsonic.lck
Java version Sun Microsystems Inc. 1.5.0_10
Operating system Windows 2003 5.2
Server Apache Tomcat/5.5.12
Memory Used 24 of 39 MB
Stack trace org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@72a11e14[file =C:\subsonic\db\subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: The process cannot access the file because another process has locked a portion of the file : C:\subsonic\db\subsonic.lck Caused by: java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@72a11e14[file =C:\subsonic\db\subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: The process cannot access the file because another process has locked a portion of the file : C:\subsonic\db\subsonic.lck at org.hsqldb.jdbc.Util.sqlException(Unknown Source) at org.hsqldb.jdbc.jdbcConnection.(Unknown Source) at org.hsqldb.jdbcDriver.getConnection(Unknown Source) at org.hsqldb.jdbcDriver.connect(Unknown Source) at java.sql.DriverManager.getConnection(Unknown Source) at java.sql.DriverManager.getConnection(Unknown Source) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:291) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:277) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:259) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnection(DriverManagerDataSource.java:240) at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:112) at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:516) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:583) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:612) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:620) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:652) at net.sourceforge.subsonic.dao.UserDao.getUserByName(UserDao.java:50) at net.sourceforge.subsonic.service.SecurityService.getUserByName(SecurityService.java:78) at net.sourceforge.subsonic.service.SecurityService.loadUserByUsername(SecurityService.java:39) at org.acegisecurity.ui.rememberme.TokenBasedRememberMeServices.autoLogin(TokenBasedRememberMeServices.java:151) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:104) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:25) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:36) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:36) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:868) at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:663) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684) at java.lang.Thread.run(Unknown Source)
eivindcom
Postby sindre_mehus » Mon Oct 22, 2007 6:34 am
This happens if more than one instance of Subsonic is running. Make sure that you have only one subsonic war file and corresponding directory in the Tomcat webapps dir. Otherwise, Tomcat will deploy multiple instances of Subsonic.
Hope this helps,
Users browsing this forum: No registered users and 71 guests
