Can Not Connect To Subsonic Server From Ubuntu 12.04
Postby precipitous » Wed May 09, 2012 10:39 pm
I am running Subsonic 4.6 on a computer running Ubuntu 12.04. Everything has been working perfectly until just a couple of days ago. Now I am no longer able to connect to the Subsonic server from any computer running Ubuntu 12.04. This includes trying to connect locally from the host machine too. It does not matter whether I try to connect using the local IP address, the public IP address or a registered DNS name - the result is always the same: a generic "time-out" message from whatever web browser I am running. Connecting from Windows clients works fine.
I tried completely uninstalling Subsonic, wiping the folder then re-installing, but it did not resolve the issue.
Since this just started happening a couple of days ago I am thinking that the problem was caused by a recent update to Ubuntu, but I have absolutely no idea where to even begin to look for the cause or a solution.
Has anyone else experienced this same issue? Does anyone have any ideas as to what may be going on? Any help would be greatly appreciated.
precipitous
Re: Can Not Connect To Subsonic Server From Ubuntu 12.04
Postby BKKKPewsey » Thu May 10, 2012 12:28 pm
are you using ssl or normal htpp?
This is certainly an odd one :? - I will be interested in what may be causing this.
(A rare 1 up for windows occurrence :D )
Postby precipitous » Thu May 10, 2012 3:48 pm
BKKKPewsey wrote:are you using ssl or normal htpp?
I am using normal http.... I posted about this issue on the Ubuntu forums as well so I will let you know if/when everything gets figured out. Everything was working perfectly until just a few days ago so I think that an update to either Ubuntu 12.04 or Firefox that is the culprit.
precipitous
