Subsonic 4.7beta1 Android app compatability?
Postby Swixxy » Fri May 18, 2012 10:39 am
Hey all, obviously subsonic 4.7beta1 is only in beta and as such is going to have things not working, but does the android app not work with it? When i try to load my Music folder the app seems to crash. Top rated, Recently added etc works fine?
Just wondering is this something affecting all users? Or is it something on my end (that perhaps i can fix!)
Edit: Seems to be working now, i believe it's an error that's caused when the library is being scanned.
So for anybody else facing this problem, wait until the library has finished scanning and it should be fine. :mrgreen:
Swixxy
Re: Subsonic 4.7beta1 Android app compatability?
Postby GJ51 » Sat May 19, 2012 12:48 am
Yes, there seems to be an issue if you try to load a folder that is being scanned. I observed the same issue initailly after install, but haven't had a recurrence since. My Sprint EVO 3G is working well with 4.7b1 with both music and video.
