Installing Subsonic on Hyper-V Core
Postby JBDive » Sat May 19, 2012 6:52 am
Anyone messed with or have any thoughts on getting Subsonic to run on Hyper-V Core (free)? I already have Hyper-V running a webserver, soon to move another server to it so why not have Core run subsonic as well. Yes I could easily stick it onto one of the VM's but why do that if you can run it on the host itself.
I have found some reference to other Java based servers being installed on Core:
Using Hyper-V Standalone OS to setup a L2J Server
http://www.l2jserver.com/forum/viewtopi ... 94&t=15383
Installing Powerchute and Install JAVA Runtime Environment on Hyper-V Server 2008 and Windows 2008 Server Core
http://bit.ly/J474Ax
So this should be possible, yes?
JBDive
Re: Installing Subsonic on Hyper-V Core
Postby Damek » Wed Jun 26, 2013 8:22 pm
Anyone try this or have any info? Could one install Subsonic on the Win Server with the GUI active, and then disable the GUI (i.e., http://goo.gl/aIQbi) ? I guess I'll be the one to try it if no one else has, but just wondering...
Damek
Postby daneren2005 » Wed Jun 26, 2013 9:11 pm
Subsonic itself is completely headless, so I don't see why not. The GUI parts are only there so that windows users can interact with the server as far as I'm aware :D
Users browsing this forum: No registered users and 55 guests
