2147484113.80 GB of music... [Resolved]
Postby Nico » Sat May 19, 2012 12:21 pm
Subsonic 4.6 was running fine on a vista 32bit box until it started to report 2147484113.80 GB although I don't have this much storage :? After a rescan, a reboot and a rescan it keeps reporting this erroneous number. Does anyone have an idea how to fix this without deleting vital parts of the install?
Nico
Re: 2147484113.80 GB of music...
Postby BKKKPewsey » Sat May 19, 2012 1:12 pm
Whoy!! that is some serious music collection :lol:
First thing to try is to delete the browser cache.
Then refresh the browser.
If that doesn't work delete the jetty cache
Stop SS
Goto
C:\subsonic\jetty\xxxx\jsp\org\apache\jsp\Delete whats here
Restart SS
Refresh browser.
Postby Nico » Sat May 19, 2012 7:10 pm
Thanks for your quick reply BKKKPewsey; followed your procedure but to bad it didn't work.
Any more tips/tricks?
Nico
Postby gurutech » Sun May 20, 2012 12:03 am
Try removing any folders you have defined (in the configuration, don't delete the actual music!), then re-index, re-add, and re-index again...
gurutech
Postby Nico » Tue May 22, 2012 8:18 pm
fixed it; copied the subsonic\db folder, deleted the entire subsonic folder, reinsall, replaced db folder, applied patches + licence and reconfigured subsonic + the agent.
all the other less painfull options failed... thanks for the additional tips though :)
Nico
