Error Log
Error Log
Postby loulou » Wed May 23, 2012 5:00 pm
Hey,
I Have 2 questions:
1 // When I go to my log, I see several error java: :| :|
java.lang.Exception: Could not find router
at net.sourceforge.subsonic.domain.SBBIRouter.findRouter(SBBIRouter.java:45)
at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.findRouter(NetworkService.java:188)
at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:132)
at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:309)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:351)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:178)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:165)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:267)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:679)
Caused by: java.io.IOException: Operation not permitted
at java.net.PlainDatagramSocketImpl.send(Native Method)
at java.net.DatagramSocket.send(DatagramSocket.java:629)
at net.sbbi.upnp.Discovery.sendSearchMessage(Discovery.java:249)
at net.sbbi.upnp.Discovery.discoverDevices(Discovery.java:187)
at net.sbbi.upnp.Discovery.discover(Discovery.java:154)
at net.sbbi.upnp.impls.InternetGatewayDevice.lookupDeviceDevices(InternetGatewayDevice.java:251)
at net.sbbi.upnp.impls.InternetGatewayDevice.getDevices(InternetGatewayDevice.java:203)
at net.sourceforge.subsonic.domain.SBBIRouter.findRouter(SBBIRouter.java:43)
2// I observe an error upnp :| :|
WARN NetworkService - Failed to find UPnP router using WeUPnP library.
WARN NetworkService - Failed to find UPnP router using SBBI library.
thank you for your help
loulou
Re: Error Log
Postby bushman4 » Wed May 23, 2012 6:33 pm
It sounds like you have "Automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding)" checked off on the Network Settings page, but your router does not support UPnP or NAT-PMP.
Uncheck that option.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Error Log
Postby supra92 » Thu May 24, 2012 5:07 am
Library as of 2012-04-30:
5,570 artists
9,398 albums
105,285 songs
2,715.77 GB (~ 42,188 hours)
How stoked are you to be just 602 albums away from 10,000? :-) I just topped 4,000 not too long ago, so 5K is my next milestone.
supra92
Re: Error Log
Postby loulou » Thu May 24, 2012 8:32 pm
Thx bushman4 for your information at the java error appears not to be put in log are empty :-)
UPNP but there is always the same error (WARN NetworkService - No UPnP router found.) yet in my router's UPnP option is enabled ???
loulou
Re: Error Log
Postby BKKKPewsey » Thu May 24, 2012 10:18 pm
All that error is basically saying is that SS (java) cannot find your router in its predefined library of routers - hence does not know the correct command syntax to send.
If port forwarding is working correctly - then just ignore it or if not forward the port manually in the router.
To stop the error message (after manually forwarding the port) just turn off the option in settings/network.
Re: Error Log
Postby bushman4 » Fri May 25, 2012 3:21 pm
5,570 artists
9,398 albums
105,285 songs
Pretty stoked... I was psyched to go over 100k songs a few months ago, now this is next!
Glenn (443 to go!)
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
