Subsonic is amazing! Except with sshfs :/
Postby theVDude » Fri May 25, 2012 11:24 pm
Subsonic runs as root, so it shouldn't be read/write problems as far as I can tell, but I've got most of my music on my main netbook, and have no trouble using sshfs to mount and browse it through the command line on my main netbook. But when I try to use it in subsonic, it tells me "no media directories found" or something similar to that.
I'm doing an upgrade and reboot on my server real quick, then I'll try again.
Any idea why it wouldn't be working?
Solved by not using root. I don't know why root would CAUSE a problem like this, but I'm in the "don't root if you don't have to" camp.
theVDude
Re: Subsonic is amazing! Except with sshfs :/
Postby theVDude » Sat May 26, 2012 12:48 am
upgrade and reboot, still not working. ヽ(#`Д´)ノ ︵ ┻━┻
Log says: [2012-05-25 22:03:12,920] INFO MusicFolderDao - Created music folder /home/robert/moremusic
mounted with: sshfs 192.168.1.11:/home/robert/music ~/moremusic -o transform_symlinks,follow_symlinks
No warnings or errors in the log, and the files work fine in mocp or other media players. :/
Just purged it completely and tried again, no luck. still. So I tried the 4.7 beta, and still not working. WHAT DO I HAVE TO DO TO GET MY MUSIC?!
theVDude
