Strange log !!!
Strange log !!!
Postby gothax » Sun Jun 03, 2012 5:36 pm
I install subsonic on my NAS synology (411Slim) with java 7. It 's work fine but my log have this strange message every 10 sec !
[6/3/12 5:51:02 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 5:56:21 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:01:36 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:08:04 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:11:48 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:11:59 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:12:09 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:12:20 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:15:05 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:27:56 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:28:06 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:28:17 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:28:28 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:28:39 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:29:12 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
[6/3/12 6:30:42 PM GMT+01:00]   INFO   RESTRequestParameterProcessingFilter   Authentication failed for user gothax
But :shock: i can connect subsonic with my account gothax
Can you help me ???
Thx a lot !
gothax
Re: Strange log !!!
Postby BKKKPewsey » Sun Jun 03, 2012 9:03 pm
I assume you have read viewtopic.php?f=2&t=9202
Re: Strange log !!!
Postby gothax » Mon Jun 04, 2012 7:52 pm
Thx a lot but i put java 1.6 and it is the same problem :shock:
gothax
Re: Strange log !!!
Postby GJ51 » Tue Jun 05, 2012 6:02 am
Delete user "gothax".
Re: Strange log !!!
Postby muvipix » Wed Jul 18, 2012 5:40 pm
I have this same exact problem, except mine says ... "user ron" - I don't have a user ron to delete; although my server subdomain is ron. I've tried all the recommendations after searching for the terms and it's still happening. What's causing it?
muvipix
Re: Strange log !!!
Postby muvipix » Fri Jul 20, 2012 12:02 am
Anyone have any idea?
muvipix
Re: Strange log !!!
Postby sindre_mehus » Fri Jul 20, 2012 10:35 am
These requests comes from one of the Subsonic apps. Either an app you have installed yourself and forgotten about, or maybe some other user somewhere has once used the ron.subsonic.org domain name and not updated his app settings.
To avoid it, change the xxx.subsonic.org domain name in Settings > Network.
Cheers,
Re: Strange log !!!
Postby muvipix » Fri Jul 20, 2012 2:51 pm
Thanks very much!
muvipix
Re: Strange log !!!
Postby muvipix » Fri Jul 20, 2012 3:15 pm
Hm, changed the sub-domain name (restarted server) and it's still happening?
I cannot figure out what's causing it?
Edit: Let me add that I unchecked the "Access your server over the Internet using an easy-to-remember address." and it's still happening?
muvipix
Re: Strange log !!!
Postby bushman4 » Fri Jul 20, 2012 3:52 pm
Someone on a remote client (android, iphone, something) has your server set up by ip address on their client, with the username ron and no (or a wrong) password.
Only thing I can think of is to try to find out their IP address (in Windows, type "Netstat" at a command prompt and look for connections to your subsonic port) and block that IP address from connecting, either at the server or at the border router.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Strange log !!!
Postby muvipix » Fri Jul 20, 2012 4:30 pm
bushman4 wrote:and block that IP address from connecting, either at the server or at the border router.
This is easier said than done. I don't think my router supports it, does Windows FIrewall? Can't seem to find a definitive answer with a search. I can see the IP source, but it changed from somewhere in Tenn, US yesterday to Toledo, Ohio today. So I'm thinking it's server specific and not actually an individual. Or I could be wrong there, not really up on this. I've never had a user ron (especially lower case) before, so I was certainly wondering if it's just some hacker [script or otherwise] somewhere - obviously knowing the sub-domain server name. It's just weird how the attempts are variable time-wise!
muvipix
Re: Strange log !!!
Postby bushman4 » Fri Jul 20, 2012 5:07 pm
Then just ignore it, and don't create a user named ron in the future...
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Strange log !!!
Postby muvipix » Fri Jul 20, 2012 5:38 pm
bushman4 wrote:Then just ignore it, and don't create a user named ron in the future...
Glenn
You're kidding, right? This is the solution?
muvipix
Re: Strange log !!!
Postby bushman4 » Fri Jul 20, 2012 5:49 pm
What would you like for a solution? What do you envision the perfect solution to be?
I can see a few possible:
  • An option to stop logging failed logins to the log file? - I for one would like to see failed logins under most circumstances, and would forget to turn this option back on before a problem where I needed the failure records crops up
  • An option to not log failed logins from a particular username? - You already said you have no user named ron, so this one would be tough
  • An option to block access from a particular client? - Since this client is changing IP addresses (probably a roaming data client hopping from tower to tower) this would be real tough too.
  • An option to send a signal from the server to the client to say "Stop bothering me!"? - Good in principal (except that the client can't authenticate, so how can it get ANY response?) but would require a change to the server and the client, and good luck forcing this unknown remote client to upgrade.
Think about it... how would YOU implement a solution to this problem? I can't see a way.
Sorry, but I'm a realist in cases like these... "There are seldom good technological solutions for behavioral problems."
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Strange log !!!
Postby muvipix » Fri Jul 20, 2012 6:48 pm
Touche, I guess "solution" was kind of final.
You could have said you had no idea 8)
Now I'm kidding.
You make good points. However, I performed a search here in the forum and, for the most part, everyone was taking guesses as to what the problem might be - I tried them all anyway. Obviously, whatever IT is - as you mentioned - it knows my IP because it continues after I turn off the redirect. I did "share" a couple of tracks on Facebook ions ago (probably a year ago or so) and if I remember correctly, IPs are visible with that feature, but I don't think it would be the same IP today; possible, but not probable.
It's just annoying, Glenn. I'm fairly certain that if you had the problem (or anyone else), you'd want it to stop. Am I correct?
I thank you for trying!
muvipix
Users browsing this forum: No registered users and 93 guests
