[SOLVED] FLAC is not being transcoded
Postby ghostcorps » Thu Jun 07, 2012 12:06 am
Hi Guys,
I have been having some trouble getting Subsonic installed after moving from the standalone installation to the full installation. Currently my problem is that FLAC files are not being played. The details as required are below:
Problem Description: FLAC audio files are not playing
Troubleshooting Steps: I have symlinked LAME to /var/subsonic/transocde
Playback Application and version: Standard Subsonic Web Interface
Subsonic Version: 4.6 (build 2583) – December 6, 2011
Server Version: Apache Tomcat/6.0.35, java 1.6.0_07, FreeBSD (131.3 MB / 288.7 MB)
Hardware Platform: FreeBSD home server
Java Memory Limit: 100mb (I think)
Problem Filename: 01 Squarepusher - 4001.flac
Output from ffmpeg -i:
bsd# ffmpeg -i 01\ Squarepusher\ -\ 4001.flac
ffmpeg version 0.7.12, Copyright (c) 2000-2011 the FFmpeg developers
  built on Jun  3 2012 10:02:40 with gcc 4.2.1 20070719  [FreeBSD]
  configuration: --prefix=/usr/local --mandir=/usr/local/man --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-pthreads --enable-memalign-hack --enable-runtime-cpudetect --cc=cc --extra-cflags='-msse -I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --enable-libaacplus --disable-indev=alsa --disable-outdev=alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libcelt --disable-libdirac --enable-libfaac --enable-libfreetype --enable-frei0r --disable-libgsm --enable-libmp3lame --enable-libopencv --disable-libopenjpeg --disable-librtmp --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --disable-vaapi --disable-vdpau --disable-libvo-aacenc --disable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --enable-nonfree
  libavutil    50. 43. 0 / 50. 43. 0
  libavcodec   52.123. 0 / 52.123. 0
  libavformat  52.111. 0 / 52.111. 0
  libavdevice  52.  5. 0 / 52.  5. 0
  libavfilter   1. 80. 0 /  1. 80. 0
  libswscale    0. 14. 1 /  0. 14. 1
  libpostproc  51.  2. 0 / 51.  2. 0
[b][flac @ 0x804e22020] max_analyze_duration 5000000 reached at 5015510[/b]
Input #0, flac, from '01 Squarepusher - 4001.flac':
  Metadata:
    ENCODER         : X Lossless Decoder 20120407
    TITLE           : 4001
    ARTIST          : Squarepusher
    ALBUM           : Ufabulum
    GENRE           : Electronica
    COMPOSER        : Tom Jenkinson
    track           : 1
    TRACKTOTAL      : 10
    TOTALTRACKS     : 10
    DATE            : 2012
    ISRC            : GBBPW1200045
    ITUNES_CDDB_1   : 990C0B0A+231435+10+150+29783+53598+73245+90378+104720+122030+155240+186093+208298
  Duration: 00:06:35.10, bitrate: 1010 kb/s
    Stream #0.0: Audio: flac, 44100 Hz, stereo, s16
Last ten log file lines:
[2012-06-07 09:44:26,786] INFO CoverArtController - Created thumbnail cache /var/subsonic/thumbs/200
[2012-06-07 09:44:28,000] INFO PlaylistInputStream - admin listening to "Enstrobia - FLAC/01 - Angel Integer.flac"
[2012-06-07 09:44:37,487] INFO CoverArtController - Created thumbnail cache /var/subsonic/thumbs/48
[2012-06-07 09:44:52,622] INFO PlaylistInputStream - admin listening to "Ufabulum - FLAC/01 Squarepusher - 4001.flac"
[2012-06-07 09:53:45,073] INFO PlaylistInputStream - admin listening to "Enstrobia - FLAC/01 - Angel Integer.flac"
[2012-06-07 09:56:02,949] INFO PlaylistInputStream - admin listening to "Ufabulum - FLAC/01 Squarepusher - 4001.flac"
[2012-06-07 09:57:27,925] INFO PlaylistInputStream - admin listening to "AFX - Analord 01/01 - SteppingFilter 101.flac"
[2012-06-07 09:57:46,592] INFO PlaylistInputStream - admin listening to "2010 - Timestretch [EP]/04 - Timestretch.mp3"
[2012-06-07 09:58:32,394] INFO StreamController - Got range: Range[4462870,4462870]
[2012-06-07 09:58:32,394] INFO PlaylistInputStream - admin listening to "Ufabulum - FLAC/01 Squarepusher - 4001.flac"
[2012-06-07 09:58:32,851] INFO StreamController - Got range: Range[4462870,49883421]
[2012-06-07 09:58:32,852] INFO PlaylistInputStream - admin listening to "Ufabulum - FLAC/01 Squarepusher - 4001.flac"
nb. the mp3 files played fine, while the FLAC files look like they are buffering but never actually begin playing.
What have I done wrong?
Thanks for your time :)
ghostcorps
Re: FLAC is not being transcoded
Postby ghostcorps » Thu Jun 07, 2012 12:09 am
Sorry, I just solved this.
For anyone else. Just copy the ffmpeg binary to ~subsonichome/transcode/ in my case that is /var/subsonic/transcode.\
ghostcorps
