Won't play for users, admin works OK
Postby scurrie » Thu Jun 07, 2012 6:38 pm
I have been using subsonic for a while now, and it works fine for the administrator. I created a user account today, but when I log in as that user, music will not play. The progress bar just flashes briefly when you hit play. Nothing obvious in the log, it looks like everything is working correctly. The server is Ubuntu 10.04 and subsonic is at 4.5.
Log sample:
[6/7/12 11:18:48 AM PDT] INFO PlaylistInputStream teri listening to "Passion Session/01 Klimbim.m4a"
[6/7/12 11:18:48 AM PDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mnt/win7/iTunes/Music/Don Ross/Passion Session/01 Klimbim.m4a] [-f] [wav] [-]
[6/7/12 11:18:48 AM PDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/lame] [-b] [128] [-] [-]
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) configuration: --enable-gpl --enable-pp --enable-swscaler --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libogg --enable-libgsm --enable-dc1394 --disable-debug --enable-shared --prefix=/usr
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil version: 1d.49.3.0
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec version: 1d.51.38.0
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat version: 1d.51.10.0
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) built on Mar 31 2011 19:03:11, gcc: 4.2.4 (Ubuntu 4.2.4-1ubuntu3)
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/mnt/win7/iTunes/Music/Don Ross/Passion Session/01 Klimbim.m4a':
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Duration: 00:04:55.3, start: 0.000000, bitrate: 321 kb/s
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0(und): Audio: mp4a / 0x6134706D, 44100 Hz, stereo
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream mapping:
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Unsupported codec (id=86018) for input stream #0.0
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) Assuming raw pcm input file
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) LAME 3.97 32bits (http://www.mp3dev.org/)
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) CPU features: MMX (ASM used), SSE
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) Encoding to
[6/7/12 11:18:48 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=3
[6/7/12 11:23:23 AM PDT] INFO PlaylistInputStream teri listening to "Passion Session/01 Klimbim.m4a"
[6/7/12 11:23:23 AM PDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mnt/win7/iTunes/Music/Don Ross/Passion Session/01 Klimbim.m4a] [-f] [wav] [-]
[6/7/12 11:23:23 AM PDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/lame] [-b] [128] [-] [-]
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) configuration: --enable-gpl --enable-pp --enable-swscaler --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libogg --enable-libgsm --enable-dc1394 --disable-debug --enable-shared --prefix=/usr
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil version: 1d.49.3.0
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec version: 1d.51.38.0
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat version: 1d.51.10.0
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) built on Mar 31 2011 19:03:11, gcc: 4.2.4 (Ubuntu 4.2.4-1ubuntu3)
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/mnt/win7/iTunes/Music/Don Ross/Passion Session/01 Klimbim.m4a':
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Duration: 00:04:55.3, start: 0.000000, bitrate: 321 kb/s
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0(und): Audio: mp4a / 0x6134706D, 44100 Hz, stereo
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream mapping:
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Unsupported codec (id=86018) for input stream #0.0
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) Assuming raw pcm input file
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) LAME 3.97 32bits (http://www.mp3dev.org/)
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) CPU features: MMX (ASM used), SSE
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) Encoding to
[6/7/12 11:23:23 AM PDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=3
What am I doing wrong?
-Scott
scurrie
Re: Won't play for users, admin works OK
Postby BKKKPewsey » Fri Jun 08, 2012 1:23 am
I assume that particular track plays np with your normal a/c?
Try creating another user and see if that works
Postby hakko » Fri Jun 08, 2012 6:40 am
I assume you have checked at Settings -> Users that the particular user have the "User is allowed to play files" checkbox marked?
MusicCabinet developer
hakko
