4.7 Beta 2 issues on Ubuntu
Postby archrival » Sat Jun 09, 2012 9:38 pm
I upgraded my 4.6 installation to 4.7 Beta 2. I am unable to view any album as I get an access denied exception. I am running on a 32 bit Ubuntu 12.04 installation. The music files are stored on an external USB hard drive formatted as NTFS mounted with ntfs-3g. All paths have 777 permissions. Before the upgrade there were no issues accessing albums. I created a new admin user as a test, same problem. I will try a non-upgrade scenario to see what happens. [EDIT: Fresh install has the same issues]
Exception   java.lang.SecurityException
Message   Access denied to file
Java version   Sun Microsystems Inc. 1.6.0_32
Operating system   Linux 3.2.0-24-generic-pae
Server   Apache Tomcat/6.0.35
Memory   Used 85 of 126 MB
Stack trace   java.lang.SecurityException: Access denied to file
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:96)
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:76)
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:137)
   at net.sourceforge.subsonic.controller.MainController.getMediaFiles(MainController.java:151)
   at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:68)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
   at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
   at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
   at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
   at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
   at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
   at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
   at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602)
   at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
   at java.lang.Thread.run(Unknown Source)
In addition I am unable to view the playlist pane:
Exception   org.springframework.web.bind.MissingServletRequestParameterException
Message   Required int parameter 'id' is not present
Memory   Used 83 of 126 MB
Stack trace   org.springframework.web.bind.MissingServletRequestParameterException: Required int parameter 'id' is not present
   at org.springframework.web.bind.ServletRequestUtils$ParameterParser.validateRequiredParameter(ServletRequestUtils.java:537)
   at org.springframework.web.bind.ServletRequestUtils$ParameterParser.parse(ServletRequestUtils.java:522)
   at org.springframework.web.bind.ServletRequestUtils$IntParser.parseInt(ServletRequestUtils.java:558)
   at org.springframework.web.bind.ServletRequestUtils.getRequiredIntParameter(ServletRequestUtils.java:108)
   at net.sourceforge.subsonic.controller.PlaylistController.handleRequestInternal(PlaylistController.java:52)
And finally I am unable to click on Search/caching in the Settings menu:
HTTP Status 404 -
type Status report
message
description The requested resource () is not available.
archrival
Re: 4.7 Beta 2 issues on Ubuntu
Postby GJ51 » Sun Jun 10, 2012 2:34 am
A clean reinstall of Java and SS may be the easiest route to fixing it. I've got two sites on Windows running 4.7b2 with no problems.
I know some of the other Linux guts are already up on b2 as well.
Postby ytechie » Sun Jun 10, 2012 3:04 am
I'm running 4.7.beta2 on Ubuntu 10.04.3 32-Bit
ytechie
Postby GJ51 » Sun Jun 10, 2012 3:54 am
I just upgraded two 4.6 sites without any problems. One Win 64 and one Win 32.
Postby archrival » Sun Jun 10, 2012 5:12 am
I am using Tomcat with the Oracle/Sun official JRE 1.6.0_32. Anyone else in a similar scenario? I was using OpenJDK for a while but I switched before I upgraded from 11.10 to 12.04.
archrival
Postby ytechie » Sun Jun 10, 2012 5:17 am
I am using openJDK-6. Why did you switch?
ytechie
Postby archrival » Tue Jun 12, 2012 12:54 am
I switched to OpenJDK. Same error:
Java version   Sun Microsystems Inc. 1.6.0_24
Memory   Used 15 of 62 MB
   at java.lang.Thread.run(Thread.java:679)
Are you using Tomcat?
archrival
Postby archrival » Thu Jun 14, 2012 9:12 pm
I neglected to clear the work folder in Tomcat, once I did this it resolved my problem.
archrival
Postby random_guy » Mon Jul 09, 2012 3:56 pm
i have the same problem with switching from subsonic 4.6 to 4.7 beta2.
Running it on Debian Squeeze with the latest tomcat 6.x and the latest java 6.33 from Sun.
My way: Shutting down tomcat. then removing old ss stuff in the webapps dir. Copying ss beta into webapps and starting tomcat again. Everything looks ok. But i get a 404.
Also removed the ss stuff in the work dir. But still getting 404.
Switching back to ss 4.6.war everything works again.
Anyone with an idea what the problem?
random_guy
Postby random_guy » Tue Aug 28, 2012 10:08 am
*bump*
Still no idea why this happened, also i have build ffmpeg from the latest source. Same problem.
Seems alot of people have the problem by searching for the keywords.
random_guy
Postby random_guy » Tue Aug 28, 2012 10:31 am
Also i doubt this is a subsonic issue. It stopped working after some time i was using 4.6 after an security update for ffmpeg came in. I dont watch that often movies so i dont know exactly.
Only .flv works now no .avi etc. Strange thing is subsonic log only says now playing ... No error message while i get the usual access denied error in the subsonic screen.
Maybe someone can post his ffmpeg settings who use the plain ffmpeg sources?
random_guy
Users browsing this forum: No registered users and 71 guests
