limit access to an account
Postby arsonists » Sun Jun 10, 2012 6:54 pm
good afternoon, How do I set so that only can be connected only one account? This means that the same account can not connect from 2 different Ip Forgive my English, I'm Spanish and I use a translator
arsonists
Re: limit access to an account
Postby GJ51 » Sun Jun 10, 2012 8:38 pm
Easy. Only create one account and don't tell anyone the password.
Postby arsonists » Mon Jun 11, 2012 5:12 am
I want is that no one can share your username and the two are connected at a time
arsonists
Postby ytechie » Mon Jun 11, 2012 7:57 am
Basically you want multiple accounts, but each account can only be logged in at one place at one time. I wanted this feature as well, and I looked into it. Subsonic uses acegi for security. It is a Java framework that has many features, including the ability to implement what you are asking for.
http://en.wikipedia.org/wiki/Spring_Security
ytechie
Postby GJ51 » Mon Jun 11, 2012 1:00 pm
arsonists wrote:I want is that no one can share your username and the two are connected at a time
At present, there isn't any way to do that in the current version. If you're concerned about that then you shouldn't be giving accounts to users you don't trust to protect their credentials.
And these days, you probably can't trust anybody.
House was right, "erverybody lies." :mrgreen:
