Login error
Login error
Postby hindujas » Sun Jun 10, 2012 9:09 pm
First time using subsonic. Downloaded the file and open subsonic in the browser. Entered username and password as admin, but gives me an error " wrong username and password" I have going through the wiki file and it says first time when you login you should use admin? Can someone help
Canada
hindujas
AW: Login error
Postby MadEvil » Sun Jun 10, 2012 9:39 pm
Default Username & Password after fresh install is admin.
Best regards
Madsonic Developer
MadEvil
Re: Login error
Postby BKKKPewsey » Sun Jun 10, 2012 11:15 pm
Check for sillies like cap key down etc - if that doesn't work delete the subsonic working folder (C:\subsonic on windows)
and re-install. The initial database creation may have gone wrong :|
