[SOLVED] Folder Limit?
Postby Luriden » Mon Jun 11, 2012 4:45 am
I noticed two directories I have on Subsonic, both of which contain MANY subfolders inside, give me this error after clicking them once I updated to the latest beta. Having so many subfolders within these directories may or may not mean anything, but it's a coincidence if it's something else causing the problem. I'm on Windows 7 if that means anything, and everything else seems to work fine, but I can't access these two folders through my web browser or mobile apps.
Error
Exception java.lang.IllegalArgumentException
Message Comparison method violates its general contract!
Java version Oracle Corporation 1.7.0_04
Server jetty-6.1.x
Memory Used 66 of 93 MB
Stack trace java.lang.IllegalArgumentException: Comparison method violates its general contract!
at java.util.TimSort.mergeLo(Unknown Source)
at java.util.TimSort.mergeAt(Unknown Source)
at java.util.TimSort.mergeForceCollapse(Unknown Source)
at java.util.TimSort.sort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at java.util.Collections.sort(Unknown Source)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:212)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:178)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:84)
Luriden
Re: Folder Limit?
Postby MadEvil » Mon Jun 11, 2012 5:38 am
I would suggest ...
1.) Increase Memory to 256 o 512 MB in the Subsonic Service via Tray icon or/and
2.) try rollback to Java 1.6_32
... and try again scanning. Which version of subsonic do you use?
best regards
Madsonic Developer
MadEvil
Re: Folder Limit?
Postby Luriden » Tue Jun 12, 2012 4:37 am
Downgrading Java did the trick. Thanks!
Luriden
